06-29-2015, 01:52 PM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Bluebird Service Manuals DOWNLOAD THEM NOW!!! before they are gone.
06-29-2015, 02:17 PM
Cool. Now if I could only find the elusive AmTran manuals I've been lookin for...
06-29-2015, 02:57 PM
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
PM me your email address and I'll add you to the Dropbox repository and send instructions on how to access the ISIS program.
06-29-2015, 06:37 PM
don't do it...........
06-29-2015, 07:18 PM
too funny!
07-11-2015, 07:50 PM
Do you have a 1992 tc 2000 front engine. 5.9 cummins, automatic Allison transmission
Originally Posted by crazycal
Do you have a 1992 tc 2000 front engine. 5.9 cummins, automatic Allison transmission blue bird school bus service manual? Even a paper back old school manual will work
07-11-2015, 09:42 PM
Engine: 190hp 5.9 Cummins
Download it and print it out.
I have never seen the need for any of these manuals.
On newer electronic buses yes. But the older mechanical buses there is no point.
Your better off looking up the specs part by part.
Manuals for the engine, trans and all other parts are easily found on line.
07-12-2015, 06:41 PM
I've posted this a few times now.
I have a 92 BlueBird and was sent this from a friend. I haven't had a need to use it.
Does anyone see a problem with us filing and using these or should we use the one listed here instead?
I don't see these going back to 1992.
https://drive.google.com/folderview?...5Tmc&usp=gmail
07-12-2015, 08:46 PM
I think that is a great place to host that stuff.
07-13-2015, 03:11 PM
Chassis: International 1753
Engine: 6.9 International
Yes and no, I caught myself where I needed the manual for my bus(tach wiring, steering gear rebuild, and others), and no, it wasn't available for free anywhere online. So I bought the paperback manual. I've since used it, and have also helped others with similar busses to mine out. Certain wiring diagrams are useless because things have been hacked errr "repaired" over the years, but I still don't regret the purchase.
11-08-2015, 08:18 PM
Hi! I'm looking for 1999 Blue Bird TC2000 wiring diagrams. I've found a service manual using a link above, but I don't see the (accessories) SWITCH PANEL circuit diagram. Everything on this panel is not working (including wipers) and I really would like to be able to troubleshoot it myself... Thanks in advance for your help!
11-08-2015, 09:36 PM
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
Not sure if they go back that far, but did you try Wiring Schematics | Portal?
11-08-2015, 10:08 PM
Originally Posted by wunderhut
Great link! It pulled out my vehicle's info, but no manuals or schematics were found, unfortunately...
03-05-2016, 06:16 PM
Year: 1994
Chassis: AARE
Engine: Cummins 8.3L Turbo
Rated Cap: 80
The-Breeze, a belated thank you! I have a '94 'Bird and these are close enough to help me decipher what's going where in a few wire bundles. Just what I needed.
1994 Bluebird AARE "Sidney"
Cummins 8.3L Turbo
04-12-2018, 04:48 PM
Engine: Cummins 8.3l 12v
Rated Cap: 84 pax
Dead link.. ??
04-12-2018, 06:00 PM
look at the date of the previous links
04-13-2018, 06:43 AM
Rated Cap: 84 pax
2015 & 16.. Hardly historic..
04-13-2018, 10:06 AM
So, has anyone got a copy of these docs for the OP? Links go bad, people hoard, it could happen.
04-13-2018, 12:05 PM
The OP's link still works and is where I downloaded mine from. Blue Bird was very nice on the phone and snail mailed me a CD of the same exact files for my bus. Not sure what you are hunting for here.
04-13-2018, 12:14 PM
Rated Cap: 84 pax
Sorry, wasn't clear. This is dead. Looking for '92 information
