Old 11-08-2015, 08:18 PM   #11
Hi! I'm looking for 1999 Blue Bird TC2000 wiring diagrams. I've found a service manual using a link above, but I don't see the (accessories) SWITCH PANEL circuit diagram. Everything on this panel is not working (including wipers) and I really would like to be able to troubleshoot it myself... Thanks in advance for your help!
Julien is offline   Reply With Quote
Old 11-08-2015, 09:36 PM   #12
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
Not sure if they go back that far, but did you try Wiring Schematics | Portal?
wunderhut is offline   Reply With Quote
Old 11-08-2015, 10:08 PM   #13
Great link! It pulled out my vehicle's info, but no manuals or schematics were found, unfortunately...
Old 03-05-2016, 06:16 PM   #14
ohnomrbill's Avatar
Year: 1994
Chassis: AARE
Engine: Cummins 8.3L Turbo
Rated Cap: 80
Originally Posted by The-Breeze View Post
I've posted this a few times now.
I have a 92 BlueBird and was sent this from a friend. I haven't had a need to use it.
Does anyone see a problem with us filing and using these or should we use the one listed here instead?
I don't see these going back to 1992.
https://drive.google.com/folderview?...5Tmc&usp=gmail
The-Breeze, a belated thank you! I have a '94 'Bird and these are close enough to help me decipher what's going where in a few wire bundles. Just what I needed.
1994 Bluebird AARE "Sidney"
Cummins 8.3L Turbo
ohnomrbill is offline   Reply With Quote
Old 04-12-2018, 04:48 PM   #15
Engine: Cummins 8.3l 12v
Rated Cap: 84 pax
Dead link.. ??
N'om'ad is offline   Reply With Quote
Old 04-12-2018, 06:00 PM   #16
Rivetboy's Avatar
look at the date of the previous links
Rivetboy is online now   Reply With Quote
Old 04-13-2018, 06:43 AM   #17
Rated Cap: 84 pax
2015 & 16.. Hardly historic..
Old 04-13-2018, 10:06 AM   #18
So, has anyone got a copy of these docs for the OP? Links go bad, people hoard, it could happen.
Old 04-13-2018, 12:05 PM   #19
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
The OP's link still works and is where I downloaded mine from. Blue Bird was very nice on the phone and snail mailed me a CD of the same exact files for my bus. Not sure what you are hunting for here.
Old 04-13-2018, 12:14 PM   #20
Rated Cap: 84 pax
Sorry, wasn't clear. This is dead. Looking for '92 information
