Old 03-20-2015, 06:02 AM   #21
Coachwork: ward
Chassis: international
Engine: dt360a
good post booyah, thanks!
Old 03-20-2015, 11:32 AM   #22
Chassis: International 1753
Engine: 6.9 International
Crap, I just looked and seen I only linked one page. Here is the album with all the pages. Park Brake Photos by bings_5082 | Photobucket
Old 03-21-2015, 05:58 AM   #23
Coachwork: ward
Engine: dt360a
whatcha got on replacing the speedo cable? thanks
Old 03-21-2015, 09:50 AM   #24
I'll have to look it up. There's three separate manuals and they aren't the easiest things to navigate through. That and the fact that they are 30 years old makes them kind of fragile too so you have to be careful flipping through them.
Old 03-21-2015, 10:18 AM   #25
Coachwork: Bluebird?
Chassis: 26ft Bluebird TC2000
Engine: Cumming 5.9 12v, AT545
Originally Posted by Booyah45828 View Post
Here are the pages you asked for. I'm going to link them versus embed because they are huge. http://i816.photobucket.com/albums/z...psteudagjs.jpg
You wouldn't happen to have a tach on your bus would you?
Sweet thanks! And yes, although it's very bouncey.
dalez is offline   Reply With Quote
Old 03-25-2015, 11:17 AM   #26
Would you know if it is mechanical or electrical? Reason I ask is I'm trying to put a tach in mine. I have an electric one but I believe it is for a gasser because it doesn't work with the sensor on the flywheel. I have a mechanical tach as well and I can't figure out what I would route the cable to(injection pump, timing cover, etc.)
Old 03-25-2015, 12:53 PM   #27
Here's all it has for that. Kinda limited if you ask me but I don't think it'd be all that complicated.
http://i816.photobucket.com/albums/z...psfbqzr8wz.jpg
http://i816.photobucket.com/albums/z...pshtjjedr3.jpg
Old 03-26-2015, 06:02 AM   #28
Coachwork: ward
Engine: dt360a
yep , straight forward! preciate it man!
Old 04-14-2015, 05:06 PM   #29
Booyah, sorry took so long to get back. My speedo and tach are both mechanical.
I also located an interested fuel leak. It's the return line that hugs the side of the block coming from the IP. It goes into a 90, follows the block a foot then turns to hard line, continues to rear of engine where it hits a T to the injectors, then rubber hose to the tank. The rubber was leaking under the clamp holding it to the block.
The interesting part is, the fitting where it goes from rubber to metal hardline has a small orifice, rather than a hardline-sized opening! We took it to NAPA, they looked very confused and wished us luck. Why the small orifice?? To intentionally cause backpressure on the IP? Anyone got a part# for this piece of hose?? Thanks in advance!!
Old 04-15-2015, 08:23 AM   #30
Yes, a lot of them use a fixed orifice in the return line in order to create lift pump pressure in the injection pump. The pressure in the pump is pretty important to filling the plungers full of fuel after the delivery valve closes. You'll have to get that hose from International.
Old 04-15-2015, 09:44 AM   #31
Makes perfect sense, I guess I expected a regulator or orifice in the IP to handle that rather than in a hose... Got a part# in your magic shop manual by chance?
Old 04-17-2015, 11:30 AM   #32
No sir I don't see any.
Old 04-17-2015, 11:32 AM   #33
Heh, guess what, I just now got the # from international, which I shall post here in case some other googler comes across this: 1806503C1 is the fuel return hose with the tiny orifice on one end. They want $80 for this footlong piece of hose. o__o
Big Mac I bought for $500!!!!! M1031 Short-Bus Conversion Projects 110 09-23-2017 02:05 PM
Dodge bus wanted (link to Craisglist post + contact info) Skunky Bus Classifieds | Buy, Sell, Swap 9 03-13-2015 06:04 PM
general bus info wanted newtoskool Conversion General Discussions 16 06-03-2010 03:44 PM
Bought a bus! Abbott Conversion General Discussions 0 07-07-2008 08:18 PM
Rims wanted/ info? JoeA Classifieds | Buy, Sell, Swap 0 10-14-2005 09:18 AM
