Old 07-04-2012, 11:54 AM   #1
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Bus won't start it
I just replaced my battery that was under warranty for the 2nd year in a row. Last year's battery was faulty apparently. Anyway, I went to run the bus today because I haven't in about 8 months. I put the new battery in, turned the key, the dashboard lights came on and I heard a buzzing sound like I always do, then I went to start it - everything went off, no sound. Tried to take the key out and put it back in and no lights came on, nothing. I remember checking the alternator last year by doing the headlights trick and everything seemed okay. Maybe I didn't tighten the battery in enough to the wires? Or the heads of the battery are just dirty? Or maybe it is the starter. Heard it could be a fuse (which I've had to replace a bunch in the past 12 months) Any ideas?
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 07-04-2012, 12:51 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: Bus won't start it
Sounds like a ground issue to me.
Old 07-04-2012, 01:32 PM   #3
bapos's Avatar
Hook up some jumper cables to it and see if lights get brighter and turn the key. I agree sounds like a grounding issue. May want to up bolt the ground cable to the frame or block (depending on what its grounded to) and clean them and reconnect.
Here is my school bus conversion thread http://www.skoolie.net/forum/viewtopic.php?f=9&t=10282
Pics of my conversion @ photobucket http://s18.photobucket.com/albums/b1.../School%20Bus/
Old 07-04-2012, 01:41 PM   #4
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
do what i had to do,,put a kill switch on my bird there about $50.00 at napa no more dead battery,,just make sure u turn it off,so charge u battery real good and do the switch..u gat a bad wire some where and u will never find it i been thought the my hares 5 time and still an't find it ,so i put a switch and hock a small light on the kill side so u know it off,,i put a red marker light,so when it kill the light is off.
keith is offline   Reply With Quote
Old 07-04-2012, 08:48 PM   #5
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Hmm,
Ok guys I have to be honest. I am not the brightest bulb when it comes to this stuff. Could ya'll explain in basic terms what that means? I don't even know what a ground issue is lol.
I will try to disconnect and clean the battery bolts and cables to get rid of any dirt this weekend.
Also, would I be able to use jumper calbles from a Honda Civic?
Old 07-05-2012, 06:31 AM   #6
bapos's Avatar
RUskoolietailgater
The battery cables have a positive and a negitive. The positive goes to the starter. The negative will go to the frame or the engine block. Sometimes when you dont get a good connection to either of those (either batter side or engine block or starterside) you wont get good connections and it wont start or charge.
Just for grins.... I would diconnect and clean both sides .... what can it hurt.
Yes any car or truck with a 12 volt battery and charging system will jump it off. You may have to let it sit for a bit to put enough charge in the battery.
What Keith is talking about is putting a battery disconnect switch in. Its a device that will disconnect the battery from the bus and not have to physically remove the cables so if you have an issue the bus wont drain the battery while sitting.
Electrical can be frustrating to find. This is not an uncommon issue with older vehicles. I have fought them before and threw many of a cuss word at them.
Fight the good fight.
Bapos
Old 07-05-2012, 08:42 AM   #7
lets start with your original problem. first, you put new charged battery in, had power up before trying to start, and then when you turned on to start you lost all power.
when this happens to me, (and it does a lot) it it because the battery cable to the battery is not tight enough, or i didnt have all the connections cleaned, or the battery cable ends are bad.
solution is to have battery posts and cable ends completely clean, and the cable ends have to securely clamp or bolt on to the battery.
the reason this happens to me a lot with vehicles is that i have more vehicles than batteries and when i need to start one, i just grab a battery and stick the cable ends on it without tightening the bolts... then i gotta get out and twist the cables or something to get a good connection.
also be sure you have the positive and negative cables hooked up correctly, and be sure the battery is fully charged, cause a new store battery isnt always fully charged when you buy it.
Old 07-05-2012, 09:21 AM   #8
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
What is funny is when I got the battery I went to charge it a little bit but I couldn't really tell if it was juicing up because the amp meter wasn't moving on this portable charger I have for large trucks. Then when it wouldn't start I tried to charge it again and charge it fast and the entire amp just went off. I interpreted that as the battery being fully charged. I am going to TRY and do this before the weekend and I'll report back if it works. (Hoping this is the problem - it actually happened once before that I just had to clean the battery bolts).
Old 07-05-2012, 11:32 AM   #9
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
sometime the short is in the wireing harnes on a p+ side,it could be in the over head light harnes or the door buzzer,u will never fine it.so do like i did and have no more troubles...of corse i toke out my harness,
Old 07-05-2012, 02:04 PM   #10
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
keith I like the kill switch idea but I still think I need to find the problem first. I don't think a kill switch is suddenly going to allow me to start my bus.
where is the best place to start? LandLubber Conversion General Discussions 10 12-05-2014 02:21 PM
Where to start? livingourdreams Classifieds | Buy, Sell, Swap 9 11-30-2011 10:50 AM
Help - my bus won't start GoneCamping GM | Chevrolet Drivetrain 7 09-21-2008 12:13 PM
Hard start/no start DT 466 Abbott Conversion General Discussions 18 11-26-2007 05:24 PM
Bus won't start, Please Help!!! ontheroad Everything Else | General Skoolie Discussions 3 11-04-2006 12:02 AM
