Old 03-03-2016, 11:34 AM   #1
Buying The Bus: Mileage and Engine Hours
So, I'm on the cusp of heading down to a dealer to start looking for my final selection to purchase for my conversion. But there is a major question I need some guidance on. I don't want a load of drivetrain work out of the gate. Obviously ideal mileage and engine hours would be 0 and straight off the assembly line. And obviously a very well-maintained 150,000mi or so diesel engine is still tough to kill.
So here's the question: What combination or average of mileage and/vs engine hours should I consider acceptable when buying my used Skoolie for conversion?
Thanks for any and all guidance fellas and ladies...
-Matt (aka Radio Ditch)
Pro Photographer, Ham Radio Op, Offspring #2 of a couple ex-hippies.
"Buy the ticket, take the ride." -Hunter S. Thompson
RadioDitch is offline   Reply With Quote
Old 03-03-2016, 11:46 AM   #2
If you go diesel, most bus engines are good up to 500K with reasonable maintenance so gauge it by how many miles you hope to add to whatever number the unit has. Obviously, lower is better, but the maintenance aspect is hugely significant. Anything from 200K down should be OK.
Gas is a whole nuther story and personally I wouldn't even consider a gas engine no matter the mileage for anything other than a twice a year, local tailgating rig.
Just my 2 centavos.
Old 03-03-2016, 01:01 PM   #3
opus's Avatar
Chassis: All-American R/E
Hours will dictate more to you than miles will. Engine model depends on the hours too. An 8.3 with 8000 hrs is a lot different than a 7.3 with 8000 hrs.
Old 03-03-2016, 07:22 PM   #4
Originally Posted by Tango View Post
Just my 2 centavos.
Both your 2 centavos are appreciated Tango & Opus! There was never a question in my mind about my bus being a diesel. It will be for sure. The two buses I am leaning towards are both 2002 T444E 7.3 V8's with about the same stats of 178160mi, 11900h, 14.9mph avg.
Think that's a bad combo?
Old 03-03-2016, 07:27 PM   #5
opus's Avatar
That's a lot of hours!
Old 03-03-2016, 07:35 PM   #6
So what would be a more acceptable amount of hours (or average mph) to start a conversion with a 150k-180k mi diesel?
Old 03-03-2016, 07:43 PM   #7
The 444E should be good for 300,000 miles in school bus use.
Anything less than 200K miles should be fine if the bus has had any sort of reasonable preventative maintenance.
The real problem in the school bus world is school buses spend more time at idle than anything else. Between the several times they start up and shut off, the many times they are stopped on route loading and unloading, and loading and unloading at schools it amounts to a lot of time running but not going anywhere. It is exacerbated by the fact most school buses spend their entire service life at less than 35 MPH.
What operators are discovering is the newer emission controlled buses have a really hard time getting hot enough to make the emissions controls (exhaust gas recirculation and catalytic convertor) to work properly. More and more operators are opting for small engines that have to work really hard rather than big engines that only have to lope along.
As long as the price is right I would not be afraid of a bus with a T444E with under 200,000 miles.
Old 03-03-2016, 07:54 PM   #8
Thanks for the guidance Cowlitzcoach. Thankfully both of my main potential candidates have their maintenance records fully intact, and ready to be handed over on purchase, and both reflect appropriate TLC in the shop.
Making the plunge soon, whether it's one of these two or another. And I cannot wait.
Ready for road life again.
Old 03-03-2016, 08:04 PM   #9
opus's Avatar
Cowlitz would know better than me. I would never expect the same hours out of a V8 that I would an inline.
I didn't read enough to know you had all the records, that goes a long way!
I've never had much good to say about V8's other than the 3408 or a 2 stroke Detroit. Well wait, the V8 Mack was a nice engine.
Disregard anything I've said. Lol.
