Old 05-01-2013, 09:13 PM   #1
Year: 90
Coachwork: Volunteer
Engine: 366
Buzzer electrical
Anyone have any idea what the gold colored Lil box is at the bottom of the panel, it's buzzing and only started after I undone the Wire connectors in the upper panel at the back of the bus. And then plugging back in.
Six Four is offline   Reply With Quote
Old 05-01-2013, 09:58 PM   #2
frank-id's Avatar
That is a warning buzzer
With the key on, test to find which wire has 12volts. The other wire must be grounded. With key on, remove wire that is not 12volts and ground where other wire was connected, and the buzzer should buzz. When ya disconnected something, the wire must now be grounded. These buzzers are often used for the door warnings. Just my long distance guess. Frank
Old 05-01-2013, 09:58 PM   #3
frank-id's Avatar
With the key on, test to find which wire has 12volts. The other wire must be grounded. With key on, remove wire that is not 12volts and ground the other wire, and the buzzer should buzz. When ya disconnected something, the wire must now be grounded. These buzzers are often used for the door warnings. Just my long distance guess. Frank
Brake Pressure Warning buzzer? Jaybus Alternative Fuels | Electric, Propane, Wood Gasification, etc. 5 03-20-2013 09:11 PM
Electrical Help levitayelor Electrical, Charging and Solar 34 02-09-2012 06:21 AM
Emergency exit/ignition buzzer/lockout busdriver_phil Conversion General Discussions 0 07-19-2010 08:50 PM
wheel bearings getting warm ? buzzer going off GoneCamping Mechanical and Drivetrains 3 10-13-2009 11:15 AM
? BB TC2000 arm rest buzzer Elliot Naess Everything Else | General Skoolie Discussions 6 04-10-2007 12:04 AM
