Old 06-30-2010, 10:29 PM   #11
Will's Avatar
Engine: DTA 360, Fuller 6-speed
Rated Cap: 53
Re: Check your U-bolts!!!!!
My '91 Thomas has zero u-bolts. The body is clamped to the frame with clips inside of the frame rails. Look at your again and see if you have them. In this picture of the box my 50amp cord rides in, you can see the clamps right at the top of the box.
My bus conversion
Will is offline   Reply With Quote
Old 07-01-2010, 05:39 AM   #12
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Yikes Will!!! That looks a bit scary to me. I'd need to know how thick and effective those clamps are. I'm curious to know how thick they are whenever you get a chance.
M1031 is offline   Reply With Quote
Old 08-02-2010, 05:24 PM   #13
Check your rear axle U bolts too I drove quite a while with a broken one, I kept hearing a clunk when braking hard and could never pin point it until one day I noticed the U bolt broke, a local axle shop made me up 2 news ones I installed the one and kept the other as a spare, spring guy said they break all the time.
hoser is offline   Reply With Quote
Old 08-17-2012, 01:09 PM   #14
working on the conversion shortly after getting my '91 bluebird, over a period of about a week we would hear these loud bangs. sure enough, it turned out to be the 4 front u bolts. all broke in the same place. a couple of months ago, parked in a buddies driveway overnight, the same bang. this time we knew what it was and got a new ubolt on b4 the rest went again. cut the old one off with a grinder. lucky it's a cheap fix.
wheeler is offline   Reply With Quote
Old 10-05-2012, 12:47 PM   #15
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
I don't know if it is a U bolt but we have been riding without something on our axel for 2 years now. Mechanics tell me it is $20 to replace and helps the body not slam down on the axel when hitting bumps. Wondering if this is it...
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 10-05-2012, 01:59 PM   #16
Chassis: TE2000 FE
Engine: 5.9L Cummins
its called a bump stop.
Chuck
cschlessman is offline   Reply With Quote
RIVET vs SPOT/PLUG WELD vs "BOLTS" vs GLUE etc. ol trunt Everything Else | General Skoolie Discussions 2 03-04-2014 11:42 AM
Ford 7.3l turbo bolts back out. roach711 Ford Drivetrain 1 03-29-2012 05:39 PM
Check this out Redbear Everything Else | General Skoolie Discussions 5 04-24-2009 05:37 PM
Seat Bolts Rusted Through Skoolie BOBB Conversion General Discussions 1 07-07-2005 11:59 AM
Nuts, bolts and busted knuckles Vern1 Conversion General Discussions 2 03-18-2004 02:29 PM
