Old 07-16-2015, 05:04 PM   #1
Clunk...
Bus has developed a clunk when turning quickly to the right. Feels like right under my feet while driving.
Jacked up the left wheel and there's a bit of movement using a 3 ft bar at the wheel, I reach around and can feel movement at the brake drum, the shoes don't move. Nothing at the kingpin.
Assuming I need to snug the bearings. I have oil bath bearings.
Difficult job? DIY tips?
Will check both sides later...Off to town right now.
Thanks for any help.
Don and Mary
dond is offline   Reply With Quote
Old 07-16-2015, 05:54 PM   #2
Check out youtube videos, lots of big truck stuff on there
Is steering box tight? How did kingpins feel? How about tre's etc?
Mine had a loud clunk, turned out to be a broken shock mount, the weight would transfer when turning wheel and clunk
Good luck
Old 07-16-2015, 06:09 PM   #3
My clunk was from tre hitting the shock and binding due to broken shock mount, maybe that sounds better
Old 07-17-2015, 01:48 PM   #4
OK, with the brake locked there's no movement using the same lever. Un-lock the brake and the wheel/hub/drum moves.
I have an appt with a local truck guy for tomorrow, he feels as I do that it's most likely just a bearing adjustment but he will give it a good looksee.
Don and Mary
Old 07-19-2015, 03:32 PM   #5
All better. DS bearings were a bit loose. Both side re torqued and new oil.
Don and Mary
Old 07-23-2015, 07:25 PM   #6
Got more clunking...
Changed into my coveralls, grabbed a pry bar and dove under. AHHA! The lower shock bolt on the DS was loose as a goose!
Leaned on it with a loooong breaker, 1-1/8 socket and took her for a test drive.
Ahhhhhh....Quiet again.
The shocks are Blue Bird branded and probably original. Going to replace them.
BB number is: 1658525
Monroe: 65121
Gabriel: 89432
Don and Mary
Old 07-23-2015, 09:13 PM   #7
opus's Avatar
Chassis: All-American R/E
Ebay or Amazon is where I got mine. Cheaper than anything else I drive.
