Old 12-29-2008, 09:22 PM   #1
the_experience03's Avatar
Re: Cold weather start
My Brazilian smokes when it's cold. It's just a natural byproduct of a cold start. The engine relies on heat generated by the compression and stored in the block to ignite the fuel-air mixture. When the engine is cold the fuel doesn't vaporize well and there isn't much heat so much of the fuel goes out the tailpipe unburned. That's the smoke you're seeing. Heck, even gassers do this. That's why secondary AIR pumps were invented and are STILL used to this day. They provide additional oxygen to burn off the excess fuel in the manifolds and pipes.
My Brazilian starts like a champ down to about 0 degrees. Below about 10-15 it will have a very angry idle and I will have to feather the foot feed for the first few seconds, but it will start. It doesn't have any form of intake heater. I have been known to use ether to help it start, but I'm not really sure it makes a difference until below 0 degrees. The key is a good, fully charged battery to allow for long enough cranking. Below 0 degrees my block heater becomes a necessity and that thing draws some juice, over 1500 watts!
Just take it easy with the ether. A gas soaked rag over the intake works very well also. Make sure your batteries are charged, and don't be afraid to feather the foot feed if it doesn't start to pop right off. Just don't rod on the thing until the idle has smoothed and you've made sure it has had long enough to get the oil flowing well to the turbo and top end of the engine. I usually give it 2-3 minutes of me feathering it before I will set it to a low high idle (say 1100-1200 RPMs).
Old 12-30-2008, 12:16 AM   #2
bus-bro's Avatar
Engine: 3208 na boat anchor
Now this is just general diesel smoke: blue=lube oil; white=bad injectors & black=too much fuel.
Of course, when it's cold, you got to let it warm up (some how) to operating temperature.
Old 12-30-2008, 11:17 PM   #3
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Originally Posted by cmpbus
. . .You can smell the bus for the next day.
A-ah-h-h! That's the smell of freedom!
Griff is offline   Reply With Quote
Old 12-31-2008, 01:54 PM   #4
Ray_WA's Avatar
Engine: 6.2 liter diesel
Rated Cap: 24
I would love to drive my bus to the party. I just don't have any beds installed yet. Still working on it.
All the more to drink all the more!!! It's New Years!!!
I'll probably go to bed early myself.
-Ray
Pack up your bus and bug out to the hills!
Ray_WA is offline   Reply With Quote
What works to start a cold diesel engine?? frank-id Everything Else | General Skoolie Discussions 12 02-03-2017 07:15 PM
weather gbstewart Everything Else | General Skoolie Discussions 5 01-16-2012 04:30 PM
How to Cold Weather Camp in Your RV lornaschinske Everything Else | General Skoolie Discussions 3 09-12-2011 02:33 PM
Window Condensation in Cold Weather arfisher83 Conversion General Discussions 10 02-17-2008 09:33 PM
Hard start/no start DT 466 Abbott Conversion General Discussions 18 11-26-2007 05:24 PM
