Old 07-31-2015, 08:03 PM   #1
Crown 10 speed
Looking on what the cost would be to replace the clutch on a 10 speed crown bus.
ben4848 is offline   Reply With Quote
Old 08-01-2015, 06:32 AM   #2
The clutch itself isn't all that terribly expensive. The expense will be in the shop time.
This is not a DIY sort of project unless you have the proper tools to do the job. That transmission is not light. Without a transmission jack that is hefty enough to handle the weight you are going to have a really hard time getting it out and back in again.
At a guess I would say a minimum cost would be in the $1,500.00 to $2,500.00 neighborhood.
Old 08-01-2015, 07:52 AM   #3
Not to mention this task has the potential to hurt you bad or even kill you if it squashes you. I think these are about 600 pounds.
c_hasbeen is offline   Reply With Quote
