Old 03-19-2021, 12:46 AM   #121
2mchprssr's Avatar
Coachwork: Freightliner
Chassis: FS65
Well I’m glad to see this is a pretty simple add on as I have a 2002 freightliner with a 3126. You guys rock for putting this thread together.
I’ll be adding this to my list along with upgrading my AT545.
Moto dad of 3 just got our first bus!!!!
2002 Freightliner FS65 30’
2mchprssr is offline   Reply With Quote
Old 07-20-2021, 08:57 AM   #122
Hey there, trying to do this, after confirming that pins 59,44,35 are already wired in at the ecm and running into the cab, I followed up the wires up to behind the gauges but lost them there... theirs that spare connector that two folks seemed to have as well as two other unused connectors that are three pin each altho it only has two wires going to each and a spare wire with a single wire connector (like a ground seems like) any Idea which wires behind the dash you ended up splicing into? how many wires go into each switch? thanks
foreverbus is offline   Reply With Quote
Old 09-19-2022, 08:02 AM   #123
Originally Posted by Ab01ns View Post
Here what I found last night. This is my main fuse/relay board. Look at the labelsAttachment 31739Attachment 31740
I have been trying to find a good photo of this box layout! Would you by chance be able to post a high-res photo? Mine is not even readable!
Mike_V is offline   Reply With Quote
