Hey there, trying to do this, after confirming that pins 59,44,35 are already wired in at the ecm and running into the cab, I followed up the wires up to behind the gauges but lost them there... theirs that spare connector that two folks seemed to have as well as two other unused connectors that are three pin each altho it only has two wires going to each and a spare wire with a single wire connector (like a ground seems like) any Idea which wires behind the dash you ended up splicing into? how many wires go into each switch? thanks
