07-03-2018, 05:48 PM
Diagnostic port type and location
Hello,
As the title indicates, I am trying to figure out the diagnostic port type and location for a few school bus varieties. Do school buses typically use the standard 9 pin j1939/j1708 connector? Are there any resources for finding out for individual vehicle types? I will need to find the port type and location for several bus types. The first 2 are
Blue Bird
Model: D3FE4
Year: 2013
VIN: 1BABNCPA3DF292329
Body: F430976
Engine: Cummings ISB-10
The second is
Thomas
Model: Saf-t-Liner HDX
VIN: 1T7YT4A2571278255
Body:538072
Engine:MBE-906
Any help would be greatly appreciated! Thank you
07-04-2018, 01:09 PM
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Originally Posted by Orion
Hello,
Blue Bird
Model: D3FE4
Year: 2013
Body: F430976
The second is
Thomas
Year:2007
Body:538072
Engine:MBE-906
Can't speak to other types but my 1997 International has an older 6 pin port in the rear engine compartment AND under the steering wheel. I couldn't *find* the one under the steering wheel until we removed the driver seat and unhooked the zonar that was plugged into it. I saw that it looked like one, but I just didn't understand what I was looking at until it was taken apart. My understanding is that you need a Scangauge D to read the info off ALL diesel engines, not just older ones. Qith an international if you have the VIN you can call the dealer and get info on the original build (ask for the line set ticket) including the port. I would think you could with other types as well but I can't confirm that.
07-09-2018, 01:34 PM
Chassis: International 1753
Engine: 6.9 International
Both of those busses will use the deutsche 9 pin connector, and it should be located below the dashboard, near the driver's knee area.
07-11-2018, 05:11 PM
Thanks for the help.
Any idea on a 2005 Thomas with a Caterpillar C7 Diesel?
Thomas G-280FE 2005 1T7YT4C2451158408
Thomas G-278FE 2005 1T7YT4C2251158410
Thanks so much for the help!
07-11-2018, 06:33 PM
Engine: T444E 7.3L
2007 and older wil have the older 6 pin connector under the dash with j1939. Some diag connectors may be located under the hood on driver's side.
07-12-2018, 08:51 AM
I'm thinking both of those cats will be on 1939. The only time I've seen 1708 used after the early 2000's is with the internationals. I could be mistaken though.
07-12-2018, 09:29 AM
And you think they will be 9 pin or some proprietary connector? Thanks!
07-12-2018, 10:28 AM
9 pin. i need more words.
07-12-2018, 10:47 AM
Chassis: 3000RE
It's probably a J1939/J1708 and a Scangauge D will read it. These codes refer to the 6 and 9 pin connectors I believe. I found mine in the engine compartment easily (it's in that box where you can start the engine in the back) but the one under the dash had something plugged into it which confused me. The zonar system was plugged into it.
07-12-2018, 11:03 AM
1939 and 1708 refer to the communication protocol that is used. Those codes will be used as a reference to the connector but it's not the technical name of the connector and I dont think the protocol mandates the use of the 9 or 6 pin connector.
Most busses that have the 9 pin connector will use the 1939 line and will also have a 1708 line. I think the 1708 comm line is used primarily for dtc purposes between modules in case the 1939 line fails, the majority of data will be on the 1939 line.
If it has a 6 pin, then you're likely using 1708 and the data will be on that.
With that said, most busses in the last 15 years will have 1939. All busses after 2007 will use 1939.
07-12-2018, 11:12 AM
Chassis: 3000RE
Sorry, when you said you needed more words I thought you were looking for the magic word to be able to Google about the ports and d those codes helped me. You obviously know a LOT more about it than I do!!!
07-12-2018, 11:38 AM
No, lol. There is a 10 word minimum for posts. Sorry about that, I'll put something different next time.
07-12-2018, 11:50 AM
Chassis: 3000RE
Oh!!! Ha ha!
