06-27-2015, 12:11 AM
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
Diesel fuel additives...do you use them?
Reading a bit about wear and tear caused by the new low sulfur diesel, combined with algae, got me wondering how many of you out there use additives to condition your fuel. If you use it, what kind?
I'd appreciate your thoughts...
-Dan
06-27-2015, 12:32 AM
06-27-2015, 02:25 AM
Engine: 190hp 5.9 Cummins
I also use that stuff.
06-27-2015, 06:05 AM
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Since my bus is just sitting as I work on it and before I can get it registered and inspected, I dumped a bottle of Star Brite Star Tron fuel treatment in the tank.
There is some discussion bouncing around the interwebz about adding 2 stroke oil to diesel, particularly for older engines to increase the lubricity of ULSD.
06-27-2015, 07:32 AM
wally 2stroke oil...1:128
an ounce per gallon.
seems to run quieter, and has a bit more power/speed....
liking the change so far
06-27-2015, 08:23 AM
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Marvel Mystery Oil ::Marvel Mystery Oil::
Lucas fuel additive Fuel Treatment
Power Service http://powerservice.com/
two stroke motor oil
non-detergent 30 weight motor oil
The oils depend upon what I'm doing. Power service in winter and for long term storage. Climbing mountains, two stroke, storage and short trips, non-detergent 30 weight. The engines I own seem to perform best that way. No idea as to why for the two stroke and 30 weight but those are my results for what it's worth.
06-27-2015, 09:11 AM
Stanadyne performance or WM 2 stroke.
Don and Mary
06-27-2015, 11:45 AM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
06-27-2015, 04:46 PM
Rated Cap: 19
I add Walmart TC-W3 outboard oil (1 oz per gallon) every fill up to add back some lubricity that was lost when the new low sulfur diesel came out. I also add some of the Power Service Kleen Diesel once in a while to clean the fuel system and injectors. Once a year I'll pour in a bottle of PS Clear Diesel to remove any water and algae that might have crept in there.
Keeping the tank full helps stop condensation from forming, especially in the cold months.
06-27-2015, 07:53 PM
Chassis: All-American R/E
-10 and below I use Power Service and ALWAYS keep a full tank year round.
06-28-2015, 11:04 AM
Rated Cap: 40 Prisoners
For long term storage I use PRI-D to keep the fuel fresh and 2-stroke oil for
lubricity. The PRI-G will actually bring old fuel back to refinery fresh. For
gasoline storage I use PRI-G annually, which will keep the fuel usable for
up to ten years.
06-28-2015, 12:18 PM
I'm on the fence right now about additives, I have always been a fan of the lucas brand had good luck with it in my rental business. With my new injectors I'm not sure what to use in the fuel, if anything, for the oil ill use lucas oil treatment.
06-29-2015, 11:34 AM
Chassis: International 1753
Engine: 6.9 International
In the winter, power service white bottle strictly for the anti-gel/anti-cloud protection.
There is a lot of info out there saying that ulsd is responsible for the death of old injection pumps and injectors due to the lack of lubricity. Now I'm not say it isn't, but every person in the petroleum business that I've talked to said they've addressed the lubricity issue long before the fuel hit the market. So I'm not completely sold that there is a problem with the fuel.
