Old 01-26-2012, 05:55 PM   #1
PDBreske's Avatar
Rated Cap: 1
Does a diesel run without electricity?
Obviously, it needs a battery to start and an alternator to recharge the battery, but will a typical diesel engine run without them once it's started? I'm just curious.
I'm not talking about the ancillary systems like engine gauges and lights, just the running of the engine itself.
Old 01-26-2012, 06:02 PM   #2
Re: Does a diesel run without electricity?
Yes and no
If it is mechanically injected with no electronics then yes once it is started only way to shut it off is to kill the fuel to it...good example is good old army 2 1/2 tons...to stop it you had to pull fuel shut off lever to let it basically run out of fuel.
If it has electric anything ecm injectors etc it will not run with out "\:-_+l
Disclaimer:this is a generic answer so all panties can stay unwadded
Old 01-27-2012, 09:45 AM   #3
syke's Avatar
Chassis: All American RE
bansil pretty much covered it.
My only addition is in a "runaway" situation. No electricity needed.
Both my bus and land rover are quote un quote 1 wire diesels. Mechanical injection, once started they keep on running. I love basic diesel setups.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 01-27-2012, 05:40 PM   #4
bus-bro's Avatar
Engine: 3208 na boat anchor
My engine has a solenoid that needs power to fuel the engine. At least that's how I think it works.
Old 01-27-2012, 09:56 PM   #5
syke's Avatar
I hear ya there. My 300tdi had an electric fuel solenoid. It was part of the alarm/immobilizer system.
Ryan
Old 01-27-2012, 10:10 PM   #6
sometimes they go bad, and u gotta manually start the engine. (and order another one)
Question: Simple solution to having electricity?? New Earth Electrical, Charging and Solar 37 04-13-2010 10:27 PM
Question: Simple solution to having electricity?? New Earth Conversion General Discussions 1 04-05-2010 12:55 AM
Electricity question. crazycal Conversion Tutorials and How-to's 1 07-14-2008 09:26 AM
Need advice for hooking up my electricity Shrtbusdrvr Conversion Tutorials and How-to's 9 07-17-2007 10:10 PM
Freshwater/Greywater/Propane/Electricity usage SeanF Conversion General Discussions 1 09-17-2006 09:32 PM
