07-11-2019, 11:13 AM
DT466 slowly losing coolant
Hey all,
I believe our bus is using coolant, it may or may not be getting burnt by the motor. About 1000 miles ago I marked a level line on our coolant reservoir, it's now down about 1/2" (not sure how much that is in volume). We're currently around elevation 10K, whereas we were around 1K when I marked it....not sure if that's relevant or not.
Kristen was following me in the car and had said there were a few times when puffs of white smoke came from the exhaust. That could be when I was accelerating from a downhill coast, but I'm not certain of that either or whether or not that's relevant.
I've done a cursory check for signs of leaking hoses and whatnot, but I haven't found anything. I suppose I should look more closely. Too, there has always been a faint coolant smell in the cabin, so maybe a small heater line leak behind the panel?
We did have an overheat (oil/water light) while pulling a hill outside of Denver. I pulled over right away and let the engine cool down. White smoke and coolant level changes were noticed the day after this overheating when the engine was cold. Didn't think to check the level before we headed out.
My question, I guess, is whether or not this is a normal loss of coolant or if it's something to worry about. Could this be a result of the overheat? I didn't see any coolant overflowing.....it was boiling, and at the Full line on the reservoir. I had an oil sample done about 2K miles ago and it showed no coolant in the oil. Anything I should check before I take it to someone who knows diesel engines? Should I give it more miles and watch the levels, or take it in right away? We're outside of Steamboat Springs, CO right now and not sure how to proceed.
07-11-2019, 11:38 AM
Chassis: IH
1/2" of coolant level difference could be as simple as checking on a different slope than before ... I'll go with an assumption that it's level ground before-and-after. It could be cool-and-warm level differences (many tanks do have cold and hot level markings) ... again, I'll go under an assumption the level has actually dropped and not a temperature difference level. As for the elevation difference, it could affect the reading a little, not sure if it would be 1/2" or not. That would probably be ... maybe a quart of coolant? If it were me, I'd keep a gallon or two on hand and check it regularly. Now if it ends up in the oil .........
I would definitely spring for an oil analysis next time it's due. These engines don't like being overheated and tend to drop coolant in the oil if they do. A quick shutdown may have saved you from this.
07-11-2019, 11:51 AM
Could be simple evaporation too from the tank.
Does the white smoke go away after warming up from a cold start?
Mine does that on a cold start till the engine starts to arm then goes away.
Just keep tabs on it I guess is all I can think of if no leaks visible anywhere.
Keep us posted and good luck.
07-11-2019, 11:54 AM
I hadn't thought about the level ground factor. Ambient temp might be a factor as well. I'll check it in the heat of the day as opposed to evening and see if it's different. Oil didn't look milky last time I checked, but I shall check again. I'll also send in an oil sample when i get a chance.
I've got a gallon of Peak Fleet Charge as a backup.
07-11-2019, 12:03 PM
There's a bit of white smoke at startup, but it goes away. This is the first time we haven't both been riding in the bus....she's never followed me until the other day when she noticed some white puffs of exhaust....so I'm not sure if this is something new or not. I guess I should check it out while idling, to see if the white smoke goes away or remains after the engine is warm.
07-11-2019, 03:40 PM
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
I don't think a 96 would have an EGR cooler, but if it does...
Not sure when EGRs and EGR coolers became a thing.
07-11-2019, 04:07 PM
EGR didnt come into play on the 466E until 04/05 model years..
was the coolant added after or before your opver-temp event? coolant expands as it gets hot... and the coolant reservopire cap is designed to vent pressure in excess of the rating on the cap... 10 PSI I think on the 466E.. getting it hot enough to turn on the overheat alarm is enough you may have been venting steam / coolant from the cap.. these busses typically dont have recovery like a car so it just goes on the ground..
checking your oil.. to make sure it is still diesel engine black and not milki-ness looking is something to do... a puff of white smoke every now and then could be an injector misfiring ...
I wouldnt be ready to worry about it yet.. however I also wouldnt allow it to run up above 220 on the temp gauge either.. you do only get so many of those alarms before a liner seal will let go... by the time you get close to 215-220 you should be hearing that fan Blazing under the hood...
07-11-2019, 09:30 PM
Rated Cap: 19
I've noticed my coolant level varies about 3/4" from a cold day to a hot day.
An oil analysis is a great idea if only to tamp down the paranoia.
07-11-2019, 09:46 PM
"these busses typically dont have recovery like a car so it just goes on the ground."
Just so I could keep an eye on such a situation, I ran the drain hose from the rad cap into a water bottle. Never seen a drop of coolant in it ever but it serves my purpose of determining if any coolant was getting lost.
John.
07-12-2019, 03:48 AM
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
I re-read the thread (with a little more sleep this time). You're probably on to something about a heater line leak, however, it may well be the heater core itself, and if it is a small enough leak, it could take a long time to drop enough coolant to be noticeable. A heater core can sometimes fool you on a pressure test -- but it is not something that can be left alone without consequence. Under no circumstances should you ever smell coolant in the interior of any vehicle.
Fumes from hot coolant (especially green ethylene glycol) can kill you in sufficient quantity, and at a bare minimum, make you very ill. As a taxi driver, an assigned car I leased developed such a leak and it continually made me sick, because the company was too cheap and the mechanic was too lazy to fix it right. They kept throwing stop-leak in it, and it failed within minutes every time I picked the car up again.
A simple way to diagnose a heater core leak is to bypass the heater core (either under the hood or inside) by using an appropriately-sized U-shaped pipe joint loop the feed hose back into the return hose to the engine without entering the core itself. Then run / drive again to see if you still smell coolant. It may take some time for the coolant smell to disappear, but if it does go away after bypassing the core, you have a bad heater core and it should be replaced ASAP.
Also, make sure your bus is not equipped with a secondary heater somewhere that you may not know about (unlikely, but still worth checking). If so, that could be leaking and be the source of the smell.
07-12-2019, 08:51 AM
The coolant was added before the event, about a month ago. The overheat happened while towing our truck up a long grade on 1-70 west of Denver. We were asking too much of her! It went from 210 to 230 surprisingly fast, and from now on I'll be super diligent about watching the temp. We'll also drive separately in the mountains instead of towing. The fan usually kicks on at 215-ish, but I don't recall it blazing. Could be I just wasn't paying enough attention. It was spinning when I popped the hood though. The coolant in the reservoir was at a rolling boil. The overflow line doesn't go to the ground, it seems to go to the top of the radiator. We're in town today and we have no cell signal at the bus.
I think my strategy going forward is to not be TOO paranoid but to keep an eye on everything.
07-12-2019, 08:54 AM
I've shut off the heater valves behind the firewall, so we'll see how it plays out from there. That should isolate the heater core (I think?). We shouldn't be needing cab heat for awhile.
07-12-2019, 09:06 AM
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
You should have no white smoke. Mine got a leak on the in bus heater line at a fitting. Smoke is an indicator of a worn out piston ring, sleeve or sleeve seal. Luckily for you a in frame rebuild is inexpensive and fairly easy to do.
07-12-2019, 09:33 AM
Chassis: IH 3800, 8 window
Boiling point for plain old water is 212°F. BP in a 50/50% mix with ethylene glycol is 223°, versus EG's BP of 388° at 100%.
Given "safe" operating temps, I'm wondering if either there's a lean mixture, or if there mayn't be a glitch in the gauge...
07-12-2019, 10:04 AM
Chassis: IH
I have an '01 T444E and it typically runs around 180 (by the gauge) or up to around 195 if I keep it floored. So far I've not ever seen it go over 200 (I don't like engines to run that hot). The fan kicks in (rather loudly!) at around 185-190. Some fans are viscous clutch driven (as mine is) and engage smoothly over a few seconds, some are air/electric clutch driven and kick in abruptly (often with a belt chirp or brief squeal). These clutches can and do wear out, so if the fan is just *kinda* turning but not moving serious amounts of air you may want to check it. Also you may want to check the radiator itself, both the fins (because they do get full of stuff and block airflow through them) and inside (same, except it can block coolant flow). A careful pressure washing (compressed air may work too) from behind will remove a lot of crud, leaves, dirt, etc, but be mindful not to bend or damage the radiator fins.
07-12-2019, 10:24 AM
It normally runs at 180 and I hear the fan kick on somewhere above 210 and it cools right down. I normally hear it come on, not sure I was paying attention this time though. It ran under 210 after we unhitched the truck, and only got to above 210 after some further serious mountain grades, so I pulled over and let it cool down for a while. I've never heard a belt squeal when it kicks on, but I'm not sure if it's viscous clutch or air/electric. Guess I'll look more into it when I'm back at the bus.
I'll blow out the radiator with compressed air, couldn't hurt.
07-12-2019, 01:50 PM
Chassis: IH
It probably doesn't matter which type of clutch it has, as long as it's doing the job. I believe the viscous ones - some of them anyway - can be adjusted and they tend to engage smoothly over a couple seconds. The air clutches often give a hiss of air and a rather abrupt engagement (probably more common on big trucks than school buses, but some were so equipped).
On some pushers, they may have hydraulic fans. Cheap electric fans simply won't move enough air.
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
May or may not do it. There will still be coolant in the core, and if it doesn't have a check-valve flapper (some have this to keep it from flowing backward), hot coolant could still enter from the engine and heat the residual coolant in the core. It really is best to loop feed hose into return hose for the purposes of total isolation.
White smoke on startup is indicative of coolant somewhere in the engine that it shouldn't be... (the cylinders) which sounds like head gasket or cracked head. A leaky EGR cooler can show similar symptoms, the reason I mentioned it, but as another member said, these did not exist until around 03-04, a non-issue on a 96.
Quick reference:
Black smoke = fuel
Blue smoke = oil
White smoke = coolant / DEF discharge
Interestingly enough, I drove a Toyota for a few months with a cracked head that didn't overheat or mix fluids, and drove fine. What it did do is blow bubbles in the radiator (exhaust gases pushing through the chambers and exhaust valve bowl) and gurgle the recovery tank on shutdown once operating temperature had been reached. Otherwise, as long you kept the coolant and oil topped off, it was happy. The thermostat had been removed to prevent overpressurizing the radiator and blowing it out, so it took forever to warm up in the winter. It got me where I was going, but it wasn't a 210-hp engine moving a 12,000-lb bus, either -- it was a 110-hp engine moving a 2800-lb car.
If possible, you might check for bubbles in the coolant. If the radiator has no filler cap, perhaps checking the recovery tank may do. If bubbles are present, ESPECIALLY before the engine warms up, that's bad news. Also, I'm not sure if the DT466 crossflows coolant through the intake like most engines, but if it does, possibly a leaking intake gasket?
07-12-2019, 03:21 PM
In a sealed system the boiling point is higher than normal.
07-12-2019, 06:45 PM
You gain 2-3* for every pound of pressure. A 16lb radiator cap will put your boiling point around 250*
