11-19-2019, 05:33 PM
Electrical Gremlins...
pOOp! I knew it wouldn't be easy but...
So my bus was running...
Problem: The engine won't turn over.
I've got two new group 31 battery's currently reading 12.75v
I get 12.75v at the red wire on the ignition switch until I turn the key to 'start'.
Then the voltage drops to 3.5v. Same readings at the bulkhead lug for the fusebox . When I measure voltage at the starter motor or the batteries themselves I still get 12.75v.
I've gone through the negative and positive connections to the chassis lugs and hot connections to the starter motor. I cleaned, and reinstalled the negative battery cables from the bat. box to the frame lug; and from the starter motor to the other frame lug, and several other leads all of which had varying degrees of rust & corrosion. But none of this changed a thing.
I can't even close the electric doors now...
BEFORE someone asks -- no, I haven't removed any of the emergency door wiring or anything else. All wiring (to my knowledge) is the same as when it last ran two weeks ago...
There is parasitic drain so I don't leave the batteries connected.
On a gas engine I'd be temped to jump the starter solenoid and see if that at least turns the engine over. With a 3126 Cat I'm not sure if that's a good idea or not...
I'm also tempted to simply run a new hot wire directly to the fuse box just so I can start and run the thing. Again, I'm not sure if there's anything that might be damaged by doing this.
Thinking about the wiring by-pass only because I'd like to move the bus a few miles to a new location for the winter...
11-19-2019, 06:46 PM
New off the shelf batteries will do this without a good charge to freshen them up. That voltage is low.
check all fuses
Might have blown one in the cable work you did.
Try these for starters. Wouldn't bypass nothing yet.
Maybe give the starter a few solid taps with a BFH.
Cool weather and sitting buses are known for gremlins popping up.
11-19-2019, 07:05 PM
check all fuses
What 'state of charge chart' are you using that indicates that. I'd say my batteries are at near 100%...
But even if I'm off on this, the dash cluster should still light up and the voltage gauge should show something...
The parasitic drain did discharge them, so I've already recharged them on a trickle charger. The reached a max v of 13v.
Batteries were disconnected during all my cleaning operations.
Tap the starter like an ol' dodge huh?
11-19-2019, 07:21 PM
"What 'state of charge chart' are you using that indicates that?"
Oh just what I have gleaned in my long experience.
Good luck figuring this out, experts will be here soon.
11-19-2019, 08:11 PM
Thanks!
I'm sure it will be something obvious -- after I find out what it is...
All sugestions are welcome -- anything suggested gives me more to think about...
https://www.google.com/search?rlz=1C...73.bsjEjwKJu_Y
All the fuses were good. Mostly they're circuit breakers so no visual but if the voltage is the same on both sides then I'll assume it's okay...
The actual install of my relays doesn't match the diagram on the back of the panel so I really don't have a clue which relays might control ignition.
I'm just realizing I need juice going to the starter and the ECU to start the engine. I'm just assuming the ecu's power comes from the "switched" side of the fuse panel -- otherwise, how would you turn the engine off after it's started? (this being an electric engine rather than a mechanical engine...)
11-28-2019, 08:16 PM
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
You say you have new batteries, is that a change since the last time it ran?
What, exactly, has been touched / changed since the last time it ran?
Go away. 'Baitin.
Our Build: Mr. Beefy
11-28-2019, 08:47 PM
Nope -- bus didn't come with batteries...
New batteries were the single biggest investment in the bus...
Resolved here in similar thread.
http://www.skoolie.net/forums/f38/31...l-q-29431.html
11-28-2019, 09:18 PM
Chassis: CE300
Rated Cap: 23
I'm sorry. I didn't realize you resolved your issue. Nor did I realize the last post on this thread was on the 19th! I could have sworn it was the most recent. But I am a little turkey-intoxicated.
Anyway, glad you got it worked out!
Go away. 'Baitin.
12-02-2019, 09:16 AM
And just to follow up with how the juice is flowing --
I still have parasitic drag draining the battery's -- although more slowly...
Since the bus is now at my house I had the luxury of allowing this drain to occur... With the battery's reading a low of 12.6v the bus still fires right up!
So this confirms that my problem was never a low battery charge (before it wouldn't start with battery's at a healthy 12.8v) but the amperage loss of every single wiring connection being a tad grotty...
12-02-2019, 11:50 AM
dont most batteries Level off at 12.6? if I saw thuibngs down to 12.2 or so then id suspect a parasitioce drain, but I always thought of a level battery as 12.6
12-02-2019, 12:34 PM
D'oh! Good point -- another check of the battery chart (there's so many...) shows 12.6v being 90% to 100% charged...
I'll leave the battery's hooked up and see what the rate of discharge continues to be or perhaps I did solve both issues at once...
Breaks over -- back to the grind(ing...)
