Old 10-08-2019, 02:00 PM   #1
Engine fan: Mec or elec???
So the fan clutch on mt T444e is shot. I can spin it like its totally loose. Almost zero resistance.
Trying to decide whether to install a new clutch (AAA Bus is sending me one for free), or to switch to an electrical system.
I've hear some people say electric ones don't have the power for this application, but don't other diesel truck with similar engine use electric fans?
Anyone put on an electric fan system? I see them online but the prices range from $45 to $400 and up.
Thanks!
Joe45 is offline   Reply With Quote
Old 10-08-2019, 02:24 PM   #2
Johnny Mullet's Avatar
Engine: T444E 7.3L
Regardless the old fan clutch has to be replaced. Eventually it will come apart.
Old 10-08-2019, 02:41 PM   #3
Yeah, I'm struggling with how to get it off right now.
Just need to determine whether to put in a new fan clutch, or go electric.
Old 10-08-2019, 03:41 PM   #4
Engine: T444E 7.3L
I remove them with an air chisel.
Old 10-08-2019, 04:45 PM   #5
Chassis: International 1753
Engine: 6.9 International
Use a new clutch. If you're worried about fuel economy, get an electric clutch.
Going to completely electric is asking for issues. You'll have to have some serious fans to pull enough cfm through the radiator to cool. So much, that I truthfully don't think it's possible/pragmatic.
And, at the end of the day, is it worth overheating and possibly ruining your engine by trying something like this? The mechanical clutch is a pretty reliable system, I'd keep it that way for peace of mind.
Old 10-08-2019, 08:06 PM   #6
Chassis: IH
I'd not bother with an electric fan system for a bus. You *NEED* way more airflow than most electric fans can produce. Hard working diesel engines produce a *LOT* of heat and electric fans simply don't have the same air moving capacity as the mechanical (belt driven) ones do.
No, big trucks and buses do not use electric fans. Some rear-engine ones have hydraulic fans.
Now as for your fan clutch, there is the typical hydraulic clutch (probably what you have now, as do I), air and electric clutches (the air clutch is fairly common in big trucks). Personally, I'd not bother changing from what the factory used since they are pretty reliable and long lasting.
Old 10-08-2019, 08:34 PM   #7
OK
So the regular belt driven fan it is!
Old 10-08-2019, 08:35 PM   #8
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
fans with a clutch spin freely when the vehicle motor is cool - it's supposed to be free spinning - before you junk your fan, let the motor warm up enough that the fan kicks in - if it kicks in when the motor is hot, then there is likely nothing wrong with it
Old 10-08-2019, 08:35 PM   #9
PS
Anybody know if this fan clutch unscrews clockwise or counterclockwise?
Old 10-08-2019, 08:38 PM   #10
I drove the bus into the maintenance bay at the school district where I work. The mechanic moved the fan around and said it was shot. It was about a 15 mile drive to the school.
Old 10-08-2019, 09:09 PM   #11
Engine: T444E 7.3L
Originally Posted by Joe45 View Post
PS
Lefty loosey on that engine
Old 10-08-2019, 10:10 PM   #12
Thank you kindly!
Old 10-10-2019, 03:47 PM   #13
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
Transit buses use electric fans for the A/C systems!
-Nick
WARGEAR is offline   Reply With Quote
Old 10-14-2019, 11:57 AM   #14
Yeah but cooling the A/C is a lot different than cooling the engine.
I have thought of using the old A/C condenser fans as additional cooling fans for the engine.
Have also thought of relocating that heater core from inside to outside to serve as a mini extra radiator.
Old 10-14-2019, 12:58 PM   #15
UGH! dont use an air chisel! thats hard o nthe water pump.. the 444E uses a 2 inch wrench and you use a spanner that holds the water pump stopped..
Old 10-19-2019, 04:42 PM   #16
Coachwork: GILLIG
Chassis: G18E102R2
Engine: Cummins ISC 8.3
Rated Cap: 23 sits 33 stand
Yes, but ours (GILLIG) has a 300A 24 V alternator to carry the 100A idle load on the 2 group 8 batteries in series. Engine fan runs off a hydraulic motor driven by a pump that also runs the power steering.
Transit buses are special critters!! They normally heat and cool over 50 passengers 7 days per week for 500,000 miles in their lifetime.
oleman is offline   Reply With Quote
Old 10-21-2019, 12:21 PM   #17
rv8flyboy's Avatar
Rated Cap: 41
One thing not mentioned here, unless i missed it.
Check the temps of the hoses to the radiator with a thermometer. I believe they should be within 10 or 15 degrees, anything more and u may have a clogged radiator.
I went through the gyrations of replacing the fan clutch only to find out the new clutch did the same. And after the engine got hot you could stop the fan quite easily with a rolled news paper and spin it backwards by hand.
Das where i learned to measure hose temps. If the radiator is clogged or the thermostat is hosed, you wont get enough heat from the radiator to get the viscous clutch going. On the surface it will appear as a bad clutch.
rv8flyboy is offline   Reply With Quote
Old 10-22-2019, 04:36 PM   #18
That's a good point!
I tried getting the fan clutch off using a tool rented from Oreilly's, but wasn't able to. None of the pieces fit the fan clutch nut! I returned the tool and went back to working on the bus because I am frankly sick and tired of doing mechanical work from years of struggling. Would rather use my energy to get the interior done. I love being creative, and doing the cabinets etc. is fun, but mechanical stuff on the engine I simply can't stand anymore!
I'm gonna have a local mechanic who is an International Guru do it for me. Under $50. I'm gonna have him check the hoses etc.
