01-16-2018, 01:59 PM
Engine spec ratings... comparing apples to apples
There are several engine manufactures that are used in these buses. Each engine has its own HP and torque ratings. So to compare "apples to apples", would it be wise to compare hp ratings not just then engine itself in raw form? For example, engine A is a 5.9L 250hp, engine B is a 7.3L 200hp (numbers are for example only).Would the larger HP be a better choice, all other things being considered equal? The heart of this question is it better to look at HP ratings for each bus engine or displacement?
01-16-2018, 02:24 PM
A thing to remember is that horsepower is a math function of multiplying torque and rpm and dividing by a constant (5252). Torque is the actual amount of force the engine can produce. With this said, horsepower numbers for engines that don't turn high rpm can seem really low, even though you may have gobs and gobs of torque.
A lot of these engines are limited to 2500-ish rpm. Engines that have a medium duty truck version in adition to a passenger vehicle version, you will see that the passenger vehicle version can rev much higher, and as such has a much higher horsepower rating. As an example, the lowest rated T444E (175hp) had a maximum torque of 460 (at 1400rpm) and a 2600rpm redline. The Ford version (Powerstroke 7.3) includes a model making 450 lb/ft of torque with a rating of 220hp (at 3000rpm). Which is the engine you would want for your bus? Horsepower rating only tells part of the story.
It isn't hard to find a low tuned T444E, or a high tuned 5.9 Cummins. Unlike cars, the higher horsepower versions weren't sold as luxury upgrades, they're means to an end... But there are big differences between them, the CUmmins is a 359 cubic inch inline 6, the T444E is a 444 cubic inch V8. They ultimately play in the same playground, and the bigger brothers (T466E, cummins 8.3) are the next step up in performance.
Clear as mud?
01-16-2018, 02:30 PM
Originally Posted by brokedown
Clear as mud?
This made me laugh because it is so true.
So really ,if comparing specs ,then HP "could" be tossed out while looking at torque specs alone?
01-16-2018, 02:34 PM
Chassis: International 1753
Engine: 6.9 International
Yeah and no. If you're looking at it from strictly a hp perspective then yes, engine A would be better. However, you also have to look at it from torque standpoint, RPM operating range , maintenance costs, commonality of parts, and age/wear on the engine.
Case in point is that there could be a huge difference between two competing engines that both have the same HP. An example of that coming from Cummins is the ISX385 and ISB6.7. Both are available with 385 hp, however the ISX delivers 1450 lbft of torque while the ISB gives 900. Huge difference there that hp rating alone won't tell.
It's not as simple as saying cummins is the best bar none, or the higher hp engine is always better. But sadly, that's what a lot of people want to hear and numerous people will say something to that effect.
Each engine has to be looked at on a case by case basis. Much in the same way a bus has to be compared.
01-16-2018, 02:46 PM
Even with that in mind, transmission type, number of gears, final drive ratio, and ecm programming mean just as much if not more. You need to know all the pieces to make an informed decision.
Example: ECCB got a short bus with a DT466 and a 6 speed transmission, and it's electronically limited to 55mph. I have a much less powerful T444E and a 4 speed transmission and my limiter is set at 65mph. Not knowing the whole picture, you wouldn't expect me to win any races.
01-16-2018, 02:53 PM
Chassis: Saf-T-Liner MVP ER
As an example of flexibility ...
I have a Cummins 8.3-250 hp, MD3060 trans and 5.38 Final drive. Engine is governed to 2200 rpm.
My current top speed is 67 mph @ 2200 rpm.
There are a bunch of ways I can change this.
1. Get Allison to unlock 6th
2. Change the governor springs, or shim the springs to give more rpm
3. Change the FD ratio
If I want more power, which would also improve fuel economy:
1. Slide fuel plate forwards
2. Advance timing
3. Change fuel plate
Change injectors and/or turbo and increase fueling.
I can probably release another 50 hp just by sliding the fuel plate forwards and advancing the timing.
Engine can go to 3400 rpm without changing valve springs. 3000 rpm with current set up would give a top speed of 88 mph.
The extra 50 hp would cause no trouble, the same engine leaves the factory with 300 hp when destined for RVs.
There are a myriad of possibilities
01-16-2018, 04:36 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Can't wait to see you roll coal. I've done it with my 6CTA's and is a hoot.
01-16-2018, 04:44 PM
I'm more worried about what transmission a bus has than how much HP.
That said, having high hp is nice.
01-16-2018, 04:48 PM
I got a 5 speed auto with lockup and OD.
As soon as Chris comes over and raises my top speed my bus will be pretty darn fast for a school bus.
My last shorty weighed more and only had a 175hp 444e and allison 545 and I got it up to 75 a few times. The 4.10 rear end made that possible.
With 10R's on my bus and the computer limit raised, my bus would be capable of 80+.
01-16-2018, 04:51 PM
I thought your transmission was a 6 speed with 6th gear disabled?
Wouldn't take much to get your bus rolling faster down the highway than mine, I"m just pointing out that horsepower ratings only tell part of the story!
01-16-2018, 04:55 PM
This is why we can't have nice things.
01-16-2018, 04:59 PM
No, the 3060's are 6 speeds.
The 2000's are 5 speeds and technically are capable of having a 6th gear but only later ones. Its more involved that just getting it enabled, and required a valve body and other stuff, iirc.
Totally agreed on HP ratings.
Sandi's is only 175 hp 444E and with the Allison 2000 it really feels snappy compared to my old shorty with the same engine and 545 trans.
01-16-2018, 07:45 PM
"Horsepower sell cars...torque wins races".
--- Enzo Ferarri
01-16-2018, 08:02 PM
--- Enzo Ferarri
Up to a point ... but F1 cars have 8 close-ratio gears, are very light and keep the revs up close to peak hp.
Muscle cars ... different story.
01-16-2018, 08:04 PM
Actually, the 8 speed box keeps the engine in it's torque sweet spot. Just like a big rig truck with 15 gears.
01-16-2018, 08:23 PM
I looked, it's both.
Peak torque and peak power are only about 2000 rpm apart, in an engine that redlines at 20 000 rpm.
01-16-2018, 09:21 PM
Chassis: IH
If anyone cares to do an engine swap/upgrade, how about an EMD 567 V6? It's factory rated at 600 hp, but with a top speed of 800 RPM. You'll have to monkey around with the gearing for decent highway speeds, but with nearly 4,000 pounds of torque (calculated), that thing would drag the heaviest loads over the steepest hills easily.
Of course, it is a very large ~56L (3400+ C.I.) displacement engine and tips the scales at nearly 16,000 pounds .....
01-16-2018, 09:34 PM
Rated Cap: 37,400 lbs GVWR
Nah, I've already got its kid brother in my bus.
I really would like a Napier Deltic in my bus, but it may not fit quite right. 18 cylinders, 36 pistons, 3 crankshafts (one of which rotates the opposite direction than the other two), and not a single damn valve. Yeah! 1650 BHP at 1500 RPM, and who cares about torque because it just sounds so good. Heck, let's have two for double the fun. (Guess where I grew up, and what I liked to do most in those far-away tender formative years when the best things in life were blue with yellow noses, and made biblical amounts of sweet-smelling smoke while doing 100 MPH with 400 tons behind them!)
John, always a 2-stroker
PS - remember, my bus can Suck/Squeeze/Bang/Blow in half the time of yours. How's that for one-upmanship?
01-16-2018, 09:49 PM
Then there is always this:
The 109,000-horsepower Wärtsilä-Sulzer RTA96-C, which first set sail in the Emma Mærsk in 2006, weighs in at a rotund 2,300 tons, and it's 44-feet tall and 90-feet long.
01-16-2018, 10:04 PM
But would its tires, suspension and brakes be up to the task? And don't even think about fuel consumption at that speed - we all know how wonderfully aerodynamic our buses are. (Sort of like the Bugatti Veyron whose entire fuel tank is empty after just 12 minutes at top speed.) I lose 1 MPG doing 67 MPH compared with doing 60 MPH.
