Old 08-09-2010, 08:08 AM   #1
Seeria's Avatar
Exhaust and oil pan problems
Guy I might buy a bus from says:
The last time I changed oil there was some seepage from the oil pan gasket.
The exhaust has pin holes all over and the smog tubes to the converter have rusted in half.
How hard and expensive does that sound? This is a Ford 460 91' shuttle bus (v.
Old 08-09-2010, 04:42 PM   #2
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Re: Exhaust and oil pan problems
Without looking at it this raises some red flags in my mind. The pan gasket is not supposed to leak in the first place. Pin holes means (usually) a lack of use and/or lack of maintenance. JMO.
M1031 is offline   Reply With Quote
Old 08-09-2010, 11:16 PM   #3
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
oil pan gasket is not a big deal UNLESS you have a cross member or steering linkage in the way.
for exhaust, you prob need new pipes from the headers back.
Old 08-10-2010, 11:23 AM   #4
frank-id's Avatar
Repairs to be made
Your bus needs just a few checks and repairs. The oil pan weep is common altho you should get under bus with a 3/8 ratchet, a 15-18 inch extension, and a universal swivel socket and snug up/tighten every bolt. Do not tighten bolts to an excess. The exhaust is an easy fix. Go to a muffler shop and get a quote to replace the leaking pipe or to make a pipe for you to install. In the course of owning a bus, you will need to make some basic repairs. Every skinned knuckle is a new lesson learned. After making some repairs, you will gain new information to use forever. If ya find a new challenge, write a note here, as I have answers for questions not yet asked. And I do not know everything. Frank
open exhaust on a 5.9 ? Elliot Naess Cummins Drivetrain 4 12-26-2010 04:01 PM
Routing Exhaust... bus-ted Short-Bus Conversion Projects 3 06-27-2010 01:13 PM
Semi Exhaust Lady Franklin Mechanical and Drivetrains 8 04-21-2009 11:45 PM
EXHAUST BRAKE 1993bluebird Conversion Tutorials and How-to's 11 05-22-2008 03:19 PM
Exhaust question 66ChevyTailgater Conversion General Discussions 8 10-24-2005 05:47 PM
