Old 03-06-2012, 12:52 PM   #1
Extending exhaust pipe from under bus
Hello!
In order to save the underbelly of my bus from getting soaked in fumes, I am going to extend the exhaust pipe.
Is there any reason why I can't just get an elbow piece and shoot the exhaust out the side in past the front of the rear tires?
Thanks.
hello_im_alex is offline   Reply With Quote
Old 03-06-2012, 01:16 PM   #2
syke's Avatar
Chassis: All American RE
Re: Extending exhaust pipe from under bus
I don't see why not.
Worst case you might end up covering that wheel in soot but past that I think you should be fine.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 03-06-2012, 03:18 PM   #3
lornaschinske's Avatar
Rated Cap: 89
We "turned" ours just before the rear bumper. Prior to that the exhaust was running thru the rear bumper and we were concerned that it would melt the plastic parts on the Jeep while towing. We made a turn or two which resulted in a turned down exhaust. Also got rid of a couple tiny holes in the pipe.
pic showing the big hole in the bumper the exhaust pipe previously passed thru. I think I will use it for the permanent generator/genturi exhaust.
After the "modification. This is the only pic I have of that part of the bus. If you look close where the bottom rub rail ends at the rear bumper you can just see the end of the exhaust.
Fulltime since 2006
Old 03-06-2012, 07:18 PM   #4
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Piece of cake. Go for it. Maybe $50 in parts tops.
Old 03-06-2012, 07:20 PM   #5
That will be fine,extend it atleast to outedge of tire and pickup a couple of the cheap universal hanger kits so you can support it with the first clamp at the joint and another a few inches from the end;t'll keep rocks and stuff from bending it down)should be less than $20 fix good luck...you can do this easy stuff I have faith in you
Old 03-07-2012, 03:02 PM   #6
Thanks for the support people! Yea I went to the auto parts store today and got an elbow piece of 4" pipe, 2 clamps, and 2 universal hangers which came to $97. I guess parts in Vancouver, Canada are just more expensive. Looked online but couldn't seem to find the exact pieces I needed. Oh well! Still a few hundred bucks cheaper than if I'd gotten it done at the shop.
Old 03-07-2012, 03:36 PM   #7
Old 03-17-2012, 02:53 PM   #8
Stuff's Avatar
glad to see you got that covered atleast!
Galvanized Pipe for Heater Hose? porkchopsandwiches Conversion General Discussions 10 04-12-2014 06:55 PM
Wood stove pipe questions madpsalmer Conversion General Discussions 1 10-02-2012 03:25 PM
Black Iron pipe question BUSBOZO Conversion General Discussions 1 05-15-2010 09:29 PM
Bus (diesel) end of the tail pipe, how hot? Abbott Conversion General Discussions 3 07-18-2008 08:47 AM
Stove pipe draft Demonknight Conversion Tutorials and How-to's 3 02-28-2007 08:37 AM
