05-14-2018, 06:21 PM
Chassis: Thomas MVP
Engine: CAT 3116 ta
Flushing Oil System with Diesel Fuel
I did a search of the forum and came up with nothing on this topic, so I figured I'd post here. Maybe someone has done it already.
I've got a converted 1998 Thomas MVP with a Cat 3116ta and an allison auto trans. I had a diesel mechanic come by to walk me through the steps for my first periodic maintenance on my engine today. I ordered some filters and he's going to return Thursday to perform the service with me. I've never serviced my engine before, got it in August, did the conversion, and have been living on her full time since January.
- So the mechanic recommended flushing the oil system by:
- draining the oil
- leaving the oil filter in place
- filling the engine back up with diesel fuel
- running the engine for a few minutes with the diesel fuel in there instead of oil
- draining the diesel fuel out
- changing oil and filter as usual
He said he's always done this on his big engines and the oil stays cleaner for much much longer and his engine last forever. I liked the sound of it so we're planning on doing it on Thursday.
Any thoughts? Will my engine explode!! This thread may end up being an interesting idea for people to try, or a terrible cautionary tale of a kid listening to bad advise. Either way, maybe people will benefit. I'll take a picture of what the oil looks like before the change, after the flush and new oil, in a month, and then in 6 months.
05-14-2018, 06:28 PM
Engine: T444E 7.3L
Running only diesel in the engine crankcase even for a short period of time does not sound like a good idea to me. Are you sure he didn't say to put a gallon of diesel in the engine oil and running it before draining it?
Personally, I would run a few quarts of ATF in the oil and then drain it if need be.
05-14-2018, 06:34 PM
Some times it's best to let sleeping dogs lie. Flushing with diesel will effect every seal in the motor negatively. It will also break free a bunch of crud that will now circulate through your motor before getting to the filter. Oil pump could clog.
05-14-2018, 06:46 PM
Engine: 3208 na boat anchor
Sounds like a bad idea to me. Does he have a reason for this? Diesel has low viscosity and low lubricity, and running it as lube oil, even for a short period, could cause excessive wear on the thin layer of babbitt metal in your engine's bearings. Not worth the risk.
If you operated the engine with a significant amount of coolant in the oil, and are using the diesel to flush the gunk out, you don't need to worry about the bearings. They're gone already.
05-14-2018, 06:58 PM
Sounds like a bad idea to me too.
05-14-2018, 07:03 PM
ive heard of putting a gallon of diesel or kerosene in the crankcase before draining. and running the engine 30 seconds to 1 minute and thats it.. never longer.. then you drain.
my personal method of opil changes is to drive my bus and get it all well heated iup.. (oil temp at 175 or above)... then I shut it off.. let it sit about an hour.. drain and fill.. this allows the oil to be thin up i nthe engine and will drip to the pan... the oil temp will still be close to 100 or a bit above in the pan and drains out nicely...
05-14-2018, 07:11 PM
Engine: 5,9 Cummins
Diesel fuel IS kerosene (and home heating oil, and jet fuel). And kerosene is a good solvent for removing oil and grease. So I would be careful with that.
Diesel does have a tiny bit of lubricating oil in it, which is the only difference from kerosene, but it is precious little.
If I were to fool with a "cleansing project", I would drop the oil pan and clean it out also.
05-14-2018, 08:35 PM
Year: 90
Chassis: international
Filling with diesel to flush is a very bad idea. Diesel has a much lower viscosity and could burn bearings and seize pistons. Even worse the low viscosity diesel will work its way past the rings and cause a runaway condition. Seen it. Use atf or add a few cans of seafoam and run a while before draining.
05-14-2018, 08:38 PM
Chassis: Saf-T-Liner MVP ER
Unless there is some imperative to do this differently, why not just drain the (warm) oil and replace it with fresh oil?
05-14-2018, 09:40 PM
The diesel flush is suppose to loosen all the muck that doesn't come out with the warm oil. It may not all come out with the flush, but now that you have it loosened up and fresh oil breaking it down it gets to flow through your motor.
05-14-2018, 10:06 PM
Chassis: Still dreaming about a bus
While in the USCG we monitored the engine oil for fuel oil dilution. If the oil ever reached 5% dilution we were required to change the oil. Finding the source was of course a priority. Excessive fuel in the oil causes premature wear to any moving part and can cause crankcase explosions. As an alternative I would get the engine up to operating temperature and drive for a while, drain the oil while it is good and hot. Change the filters, refill with clean oil, and repeat after a really good run. In my opinion draining the oil while hot after a good long run would remove most junk safely than the diesel.
05-15-2018, 09:24 AM
Chassis: International 1753
Engine: 6.9 International
I WOULDN'T DO THIS!
I've heard of this being done in the old days on gas engines, never a diesel. I wouldn't do it for the shear fact that ulsd fuel is a terrible lubricant. You're likely to ruin bearings and piston skirts by doing this.
If you're having issues with sludge/build up inside the engine, add some atf into the mix and shorten your oil change intervals a few times.
Maybe use a high detergent motor oil afterwards to keep it in check.
But I would definitely, without question, not use diesel fuel in place of motor oil in a running engine.
05-15-2018, 07:35 PM
I have used diesel in a 70/30 mix many times to flush an engine that had a head gasket or oil cooler leak. It works well, but I only idle the engine for 10 to 15 min. I would not do this to flush an engine for any other reason.
05-26-2018, 03:32 PM
fuel injectors are operated by the oil. i dont know ifni would try this. you might use something like seafoam or lucas. i havnt used one on a disel, but i have had goood success woth seafoam in my tank with a high compression engine. havnt teied the crankcase yet.
but fuel.... mmmmm, your oil pressure should technically be too low to run if you replacenit with all disel fuel. i can see how a small portion would thin ouy the oil and maybe clear up some gunk.
and if you dont leave it run too long thenoil ahoulsnt get thin enough to drop your pressure. injectors might malfunction if it drops.
who knows. your gamble. good luck
05-26-2018, 06:40 PM
I'd lean towards finding another "mechanic". Absolutely no reason to even try what he is suggesting. Diesel oil will be dirty, it's a carbon thing. Pay no attention to the color. Warm it up, drop the oil, change the filter (make sure the gasket comes with the old filter), refill with oil and have a great day.
BTW, that 3116 should come in right about 28 quarts so a 5 gallon bucket won't work but two will if you're good at shuffling them around.
05-26-2018, 09:32 PM
HotShot's has a really good oil additive and an awesome fuel additive. I've been running the stuff for a while now and have put it in four buses. I'm NOT into additives. But the stuff is really worth it.
05-26-2018, 10:44 PM
The closest thing I've heard of to this is using kerosene in your fuel system to clean your injectors. Earlier this year my engine was hesitating at odd times so my mechanic ran kerosene for several minutes and it really made a difference. Even with that you have to be careful because there's no lubricant in the kerosene.
Yes, they're gone if you're using diesel to flush out the gunk. But I had a top end rebuild on my 466 because of the coolant/O-rings and my bearings were fine. But I'm sure if I had added diesel to it- yikes!!!
Daddy, can we go on a trip again??
'85 Thomas SafTLiner RE
3208 NA CAT MT643
