Re: Ford B700 Fuel cut off issue
The sol. is mounted on the side of the injector pump, and is about the size of a D cell flashlight, with 3 wires coming off of it. Take note with it it the 'off' position, then go bump the starter a little with the key but leave it in 'run'. It should be in the down position, or pulling on the little lever. When you shut off the key, it should snap back to the off position, which is up. You can also zip tie it in the run position for testing purposes, just dont drive it that way.
I'd be more thinking it's got air still stuck in it. Make sure the primer pump gets hard to push, then try starting with your foot to the floor until it starts.
