Old 06-16-2012, 01:20 PM   #1
Re: from 8.2 detriot to 12v cummins???
I think it would be alot simpler than the 5.4 swap. Most likely will have to swap a transmission also.
katoranger is offline   Reply With Quote
Old 06-29-2012, 09:42 PM   #2
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
Yes, it would be easier than the gasser swap. The 12 valve will have many trans options, which a wrecking yard can help with. While you're at it, you'll need some better gears in the rear end, because you wont need that many rpm to go down the highway anymore.
nevrenufhp is offline   Reply With Quote
Cummins 235? nevrenufhp Cummins Drivetrain 2 07-28-2012 08:52 AM
The elusive Detriot Diesel 8.2L FP manual the_experience03 Detroit Diesel Drivetrain 0 11-04-2009 07:17 PM
WVO in Cummins ISB-07?? greyguzziart Veggie Oil | WVO | Biodiesel | SVO 0 07-19-2009 11:29 AM
anything have a Cummins 4BT? nearhomeless Short-Bus Conversion Projects 8 07-14-2009 08:56 PM
cummins 5.9b dieselman69 Conversion General Discussions 2 09-17-2008 04:06 PM
