Old 04-08-2019, 12:20 PM   #1
Year: 2005
Coachwork: International CE200
Engine: VT365
Rated Cap: 26
Front window trim
Hi,
While pulling up the plywood in the drivers foot-well, I found a lot more moisture then I thought should be there. It was a bit slick, so I suspect that the heater valve is leaking.
But looking at where else water might be coming from, I noticed that the corner brackets are looking somewhat rusted. It seems to be just surface rust, I suspect it was never painted and condensation on it would cause the rust.
Looking from the outside I noticed a fairly substantial gap in the window trim. Should I be worried about this. Or is there more trim behind it, and this just works as a drain hole?
Tx
Bas
brijn is offline   Reply With Quote
Old 04-08-2019, 12:33 PM   #2
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
What bus do you have? Fill out your profile, amigo
Old 04-08-2019, 12:51 PM   #3
Year: 2005
Engine: VT365
Rated Cap: 26
It had that under "My bus" but that apparently does not show up. Moved it to "Coachwork".
It's a 2005 International CE200
Bas
Old 04-09-2019, 08:31 AM   #4
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
Looks like a drain hole from what I see in your pics. But any hole out could possibly let water in. Does the corner smell sweet? That would indicate coolant as opposed to just water.
WARGEAR is offline   Reply With Quote
