08-17-2018, 10:38 PM
Chassis: Thomas
Engine: CAT 3126
Fuel filter/water separator public service announcement
For some reason I thought the water separator was not also a filter that would get plugged up. I had been emptying the water every so often so I saw little reason to change the filter, but I had one so I figured it couldn’t hurt.
When the old one came off I couldn’t believe the bus was still running. It was nearly entirely plugged. Not sure if it is algae or what. I just finished putting 7k miles on it so I know the fuel system has been well flushed.
08-17-2018, 10:50 PM
Chassis: chevy
Engine: 3116 catapillar
there is a algae that grows in diesel fuel. if you have it in your filter its in your tank and you need to get a additive to kill it
08-17-2018, 11:04 PM
What he said. If it is in the filter, it is almost certainly in the tank and likely to cause big problems at some point. Get an algaecide for your fuel.
08-18-2018, 08:43 AM
I'm not big on fuel additives but with diesels they're almost a necessity.
08-18-2018, 08:50 AM
Don, Mary and Spooky the cat.
08-18-2018, 10:29 AM
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Stupid question- is the water separator *in addition* to the fuel filter I already changed in my engine compartment?
08-18-2018, 10:46 AM
Chassis: Thomas
Engine: CAT 3126
Yes I think so, although mine were next to each other in the engine compartment. If your bus only has one for some reason I think it would be well worth it to add a water separator. The low sulfur diesel at the pump now is more susceptible to biological contamination, and water has always been an issue with diesels.
You can tell the difference between the filters because the separator has a petcock on the bottom.
08-18-2018, 01:36 PM
This stuff does wonders in my buses-
09-06-2018, 09:38 PM
Not all water separators have petcocks. Some versions use a mat that just abosorbs it, and you change it every so often. Source; Used to work at a NAPA, we sold a lot of those to the LSD bus garage
09-06-2018, 09:49 PM
Chassis: Thomas
Engine: CAT 3126
Good info. I guess you could say that if it has a petcock it is a separator for sure, but if it doesn’t have one it still *might* be.
09-07-2018, 09:59 AM
Here is the water seperator on my 1991 Bluebird TC 2000. It has 2 petcocks. Also, the silver pipe fitting on the top right is a check valve or one way valve, my old one was so worn you could blow air through it the wrong way.
This feeds a mechanical Cummins 5.9.
