Old 04-20-2015, 05:14 PM   #1
muddyrabbit's Avatar
Gear Vendors add on overdrive?
With all the threads here about how to improve highway speed I wonder if anyone has fitted a Gear Vendors add on Over Drive unit to their bus?
https://www.gearvendors.com/motorhome.html
muddyrabbit is offline   Reply With Quote
Old 04-20-2015, 05:18 PM   #2
Nevermind, apparently they don't make anything for medium duty drive trains.
Old 04-20-2015, 06:09 PM   #3
Engine: 190hp 5.9 Cummins
Would not be worth the cost or trouble any way.
Just get the right gears in the rear, done.
Gears can be had from junk yards. Gear venders stuff starts in the thousands.
Old 04-21-2015, 10:21 AM   #4
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
If you don't already have a bus I would recommend just shopping around for one that has good highway gearing already. A unit with an MD3060 trans would be ideal, cause it is 6 speeds rather than 4 or 5 and has 2 overdrive gears. Of course the rear gear ratio comes into play too.
If you already have a bus it would be cheaper / more straightforward to swap the rear gears than to do any add on trans modification.
porkchopsandwiches is offline   Reply With Quote
Old 04-21-2015, 10:25 AM   #5
crazycal's Avatar
The MD3060 has 6 gears but my understanding is that only 5 are used in a school bus application.
I'm hungry!
You Gotta Let Me Fly
Old 04-21-2015, 04:00 PM   #6
We have a crap load of buses at the shop, so I started looking.
My 96 MD3060 only go's to 5th gear.
Same bus but a 2000 has the 6th gear.
Both are 8.3 Cummins, MD3060 combo's. The 2000 is a electronic version of the 8.3, still at 250hp.
I think it's all in how they were ordered when new.
Old 04-21-2015, 09:08 PM   #7
I got mine changed over to 6, check out my thread!
