Old 05-01-2019, 05:27 AM   #1
Coachwork: IC
Chassis: IC
Engine: T444e, 7.3
Rated Cap: 12
Greasing and Lubing your Bus
Went ahead and greased up all of the grease fittings I could find on the bus yesterday.
What kind of grease do you all use when you lube up your bus?
Do you use a different type of grease on the Ujoints vs ball joints?
How often does this maintenance need to be performed?
When you grease the front end and kingpins are you supposed to jack the front end up to take the pressure off of the suspension?
I haven't seen any posts about this subject so I figure it would be nice for other members to have this info as well.
(EDIT)
Whoops! I just found this thread by EastCoastCB Sorry for the duplicate at this point.
http://www.skoolie.net/forums/f33/le...-pm-20944.html
consti2tion is offline   Reply With Quote
