Old 06-20-2017, 09:45 AM   #1
KerryBeth1985's Avatar
Chassis: Thomas Built Mini, Microbird
Engine: 6.6 Diesel
Rated Cap: 17 pass
Help! Door jam
I have a short bus with a Thomas Built chassis. Yesterday, we latched the dog leash through the door latch and when it started to rain a bit, someone closed the bus door. now of course it will not open or fully close as it is obviously locked onto the metal clip at the end of the dog leash.
We tried cutting the wire lead from the leash hoping the metal hook would fall through but no dice.
I'm thinking the door panel will have to be removed? Or that I'll just have to pay someone to fix the problem.
Suggestions?
KerryBeth1985 is offline   Reply With Quote
Old 06-20-2017, 11:01 AM   #2
Robin97396's Avatar
For me that's kind of hard to visualize how that got stuck. Got a camera?
Robin
Nobody's Business
Old 06-20-2017, 07:19 PM   #3
Engine: 6.6 Diesel
Rated Cap: 17 pass
thank you for offering to assist! much thanks. but it's all good. turns out it just needed some man power LOL. a couple of strong guys were able to force it open. yay!!! and the end of a dog leash, you know the metal part that latches? you pull it open with your thumb and hook it to their collar? that little metal doo-ma-flagee was stuck in the door latch. but yay for man power!
Old 06-20-2017, 07:42 PM   #4
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
"doo-ma-flagee" -- NO MORE TECHNICAL TERMS, please. It's hard enough trying to understand Bus-ese.
Old 06-20-2017, 08:11 PM   #5
Robin97396's Avatar
First bus issue I've heard of involving a dog leash. Yeah, brute force usually works.
More doo-ma-flagees get ruined that way.
Glad it worked out. I lock myself out of my bus another clever way. I'll crank up during the winter, go outside to clean the windows, then the air builds up and closes the door. Duh!
Robin
Nobody's Business
Old 06-20-2017, 08:21 PM   #6
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
I've done that, too. Last time it happened, I used the window scraper to push open the air valve.
Old 06-21-2017, 09:10 AM   #7
Rameses's Avatar
If you can't fix it with a hammer, you're dealing with an electrical problem.
Rameses is offline   Reply With Quote
Old 06-21-2017, 10:20 AM   #8
Robin97396's Avatar
I thought that's why they made plastic hammers? For electrical.
Robin
Nobody's Business
Old 06-21-2017, 09:00 PM   #9
Engine: 6.6 Diesel
Rated Cap: 17 pass
hahahaha! you guys are funnie! yes, do-ma-flagee, definitely a technical term. and i just got done with rough in electrical woohoo! pondering a day off tomorrow given my fine collection of small bruises, poison ivy, and the lump on my head that keeps getting bigger every time i hit it on the door jam above the back door. next work day, that thing's getting repadded! laters!
Old 06-21-2017, 09:43 PM   #10
Rameses's Avatar
Just noticed you're in Lawrence, KS.
Are you a Jayhawk fan?
Old 06-21-2017, 10:11 PM   #11
Alan N's Avatar
Year: 1975
Chassis: Gillig
I love it!
Alan N is offline   Reply With Quote
Old 06-23-2017, 08:33 PM   #12
Engine: 6.6 Diesel
Rated Cap: 17 pass
absolutely a Jayhawk fan, bigtime. Graduated from KU in 2010 (at the age of 43), a year after my eldest daughter graduated from same. She's married to an MU fan. I enjoy buying their kids KU gear LOL
Old 06-23-2017, 10:09 PM   #13
Rameses's Avatar
I went to middle school and high school with the daughter of one of your former basketball players. Guy by the name of Dean Smith.
Old 02-17-2018, 01:54 AM   #14
golfersmurf57's Avatar
Yeah ! Go tarheels! But don't forget Coach K! Duke fan myself. Ill take the ACC and give you the field!
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
