09-19-2017, 10:56 PM
Chassis: International CE 300
Rated Cap: 71 passenger / 12 window
Help me interpret this spec sticker - "Engine - EFI58I90, Trans - AT545"
Trying not to be so wet behind the ears. 2003 Thomas full size rear engine bus, up for auction. I've heard of the AT545 before but that engine code baffles me.
What can you tell me about this engine and trans combination? How well regarded is each? They say the AT545 has no lockup torque converter - there MUST be a reason for that.... right?
09-19-2017, 11:04 PM
Here's the sticker. I may be reading some characters incorrectly.
09-19-2017, 11:08 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
AT545 is the non-lockup trans some guys are exchanging for better trans.
190 HP electronic ISB 5.9 Cummins?
like this bus sticker, just rear engine?
09-19-2017, 11:09 PM
After trying a variety of different possibilities for the engine code, I think I narrowed it down to a 5.9 Cummins ("EFISB190"). The Cummins website says that it traded its rotary injection pump for a high pressure common rail system in 2003. Is that better than an injection pump or worse?
09-19-2017, 11:13 PM
like this bus?
Similar in appearance. What's so bad about the AT545? All I could see would be bad fuel economy due to no lockup... is that true? If yes, how bad, compared to a lockup version of the same transmission?
I'm naturally wary of fancy new stuff, because when it goes, it's more expensive to fix. I've had many old hydraulic 3-speed automatic transmissions without lockup, and they were relatively cheap to replace when they went... not to mention that they didn't "go" all at once. (One, in a Dodge van, took 16,000 miles to die completely from the time it started showing problems.)
09-19-2017, 11:14 PM
Traveling
Rated Cap: '00
The diesel doesn't seem to care much which way it gets squirted, still burns in the end.
Diesels are being targeted for reduced emissions, so they are trying to be more precise with fuel metering.
I have 2003 5.9L , built in '02, so I have the VP44 Injection pump. Feed it 15-18psi and it sings, don't and pay the price $$.
09-19-2017, 11:18 PM
Chassis: IH
I ran the VIN (assuming I entered it correctly) and it shows an '03 Cummins ISB 5.9 , front-engine, 78" headroom air-brake bus.
09-19-2017, 11:28 PM
Fascinating. Can you run this one (or, perhaps better yet, tell me where I can run them myself)?
Also, would you say that there is a model year beyond which you would never buy a bus no matter what the deal was? (Some people seem to think that newer buses are mechanical nightmares. This auction site shows a third bus - a 2008 model.)
09-19-2017, 11:33 PM
Chassis: IH
That's the one I ran, VIN 1T88N4D2731130068
Check 'em yourself here.
Gates VIN Decoder
I have this link bookmarked, I suggest doing that if you plan to check more than one.
09-19-2017, 11:34 PM
Crud... that's the same one. I thought it was from the second bus ad and the second bus ad doesn't have one posted. Maybe I should just have the site where you can decode these things. I'm trying one site right now and it isn't working.
09-19-2017, 11:41 PM
Gates VIN Decoder
Worked quite nicely. I ran the other VIN and it showed that the 2008 model bus has an MBE 926 Mercedes-Benz diesel engine. I found almost zero information on that engine, searching all of the forums on this website. Know anything about it?
09-20-2017, 12:05 AM
Chassis: IH
Emissions hardware equipped, I'd pass.
09-20-2017, 05:12 AM
2008- I'd pass too!
09-20-2017, 09:44 AM
2008- I'd pass too!
Is this because the "emissions hardware" is known to fail, rendering the bus inoperable or barely operable, and be extremely expensive to fix?
After all, if the skoolie community eschews any bus made before [what year, exactly?], as time goes on, there will be fewer and fewer buses available for those who'd convert one.
09-20-2017, 12:46 PM
I'd rather NOT have a bus than have that 2008 or anything with DEF, EGR, or DPF.
There are plenty of non-epa buses still out there, so I say "why settle?" when there are buses that aren't designed to melt down from some epa crap.
