08-25-2019, 11:55 AM
#41
Coachwork: Blue-Bird
Chassis: TC RE 3408
Right, I always forget the headlight fluid. Thanks for reminding me.
08-25-2019, 11:59 AM
#42
And don't forget to lube the key.
08-25-2019, 12:04 PM
#43
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Don't forget, you're supposed to check the level of the headlight fluid only after the lights have warmed up to operating temperature. Failure to do so may compromise the flux capacitor.
Speaking of which, OP... when the engine does start, what happens when you reach 88mph?
Go away. 'Baitin.
Our Build: Mr. Beefy
08-25-2019, 12:05 PM
#44
Chassis: TC RE 3408
Lubrication might actually help a little. If this had happened to me, my very first step would have been to apply some graphite-based lock lubricant, and see if that made ANY difference. Lubrication probably would not have been enough to fix the problem in this case, but it would loosen that lock mechanism up and at least eliminate that as the complete problem.
08-25-2019, 12:07 PM
#45
Year: 86
Chassis: Ford B700
Engine: 8.2
did anybody say KEY SWITCH?
i know i am late to the party again.
if not built into the switch depending on year make model etc.
ignition control module
seperate starter solenoid with the ignition contact in it
several design options depending on what you have?
if you have solenoids seperate from the KEY SWITCH check for power in and out of them with the key in its respected positions and or use a jumper wire from hot to the I for ignition and start the bus
sometimes a BFH works also
08-25-2019, 12:08 PM
#46
Chassis: TC RE 3408
Precisely 88 mph? Like in Back to the Future to initiate time travel? Cool, I'd better make sure my bus can do 88 mph, just in case I want to go sometime.
08-25-2019, 12:20 PM
#47
Chassis: CE300
Rated Cap: 23
Exactly. That's why dealerships are often reluctant to remove the governor for you. Huge legal liability if you go back in time and change the future.
Go away. 'Baitin.
08-25-2019, 12:22 PM
#48
Year: 86
Chassis: Ford B700
Engine: 8.2
funny you mention that?
i almost said in my post that if the key switch shop didnt work then he needed to stick a screwdriver in the Flux Capacitor
08-25-2019, 12:24 PM
#49
Chassis: TC RE 3408
Yes, the flux capacitor, everyone, including me, forgot about that. That's got to be where the problem is. Good call guys.
08-25-2019, 12:33 PM
#50
Year: 86
Chassis: Ford B700
Engine: 8.2
if the wiring through the key switch to ignition control module to ignition solenoid to the ECM before the BMS and then out to Flux capacitor before it energizes the motor is not making good contact you can open it up and wedge a screwdriver in between the post with a BFH does the trick everytime
08-25-2019, 01:04 PM
#51
Glad you slept on this idea. Now you are starting to understand the start circuit. Begins with turning the key and releasing it after engine start.
KISS, easy things first.
Still don't think you are qualified about electrical advice for anybody's issues.
08-25-2019, 01:31 PM
#52
Turning the key and releasing it after engine starts has been established as working. It has no bearing on the electrical part of the switch behind the tumblers. I have said nothing in this thread that is inaccurate.
Just curious, where is your bus build?
08-25-2019, 02:23 PM
#53
Year: 86
Chassis: Ford B700
Engine: 8.2
i know i am not a moderator but?
john and marc.
PM each other if you want to keep this up the OP hasnt responded but that doesnt meen that this is an open thread for yall to argue on?
the op has been given advice for his question now you to shut up until the OP responds and you have helpfull opinions to the OP.
everyone has experience in something but no one is experienced in everything
08-25-2019, 02:35 PM
#54
Year: 86
Chassis: Ford B700
Engine: 8.2
you must be reading things wrong?
original post said thee thing starts but when he/she/it lets off of the key switch after starting it dies
aint about the tumblers cause the key turns it over.
i think they have a seperate starter ignition solenoid that needs attention
08-25-2019, 02:47 PM
#55
I agreed in the beginning, it's a faulty switch. BlackJohn was the one recommending the dumb idea of lubing the tumbler, as if that has something to do with the issue.
08-25-2019, 02:53 PM
#56
Ad Hominem attack 15 yard penalty
08-25-2019, 03:44 PM
#57
Year: 86
Chassis: Ford B700
Engine: 8.2
gracias. usally say grassy ass cause it sounds the same in passing?
08-25-2019, 03:53 PM
#58
Why not both
08-25-2019, 03:59 PM
#59
Originally Posted by Drew Bru
Maybe I'm outta line here, as I'm not too mechanically inclined, but topping off the headlight fluid first might alleviate the need for new headlights.
One of my headlights is actually half full of fluid. I've been planning to replace it but maybe I just haven't been optimistic enough.
08-25-2019, 04:02 PM
#60
Chassis: TC RE 3408
Optimistic? Yes having optimism once in a while is important. Sometimes that's difficult though.
