Old 08-23-2011, 10:57 AM   #11
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Re: High RPMs?
Thank you all for the replying to this post.
I do indeed have a placard on the dash. It says 6.8 gear ratio.
I am fairly sure that the rear end gears have been changed. The only way that I will know is to do the spin the tire and driveshaft method of calculating.
My computer died but magically came to life again after two days. Weird. I sure hope it continues to work. I love coming to this site. Gonna go look at the tranny today. Hopefully I will find the tag with the data on it.
Old 08-23-2011, 04:16 PM   #12
Accordion's Avatar
Year: 1973
Re: High RPMs?
I went under the bus today and found the tag on the transmission. It is an Allison made by Detroit Diesel Company. The model is MT 640.
Anyone know much about them?
Old 08-23-2011, 05:06 PM   #13
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
Re: High RPMs?
The mt is a great and durable trans. You should get a nice, long, trouble free life from it.
nevrenufhp is offline   Reply With Quote
Old 08-27-2011, 05:17 PM   #14
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: High RPMs?
Originally Posted by nevrenufhp
I was only saying it was the calculation, not the actual gears. I'd be more inclined to say 5.13s or 5.29s too. With at best of 210hp & no turbo, it would have a real hard time with 4.10 gears. If it had more power, 4.10s would be great.
Yes, going 60 will also help fuel economy too.
I have 4.10's and only 200HP...it works beautifully!
Jarlaxle
Old 08-27-2011, 05:19 PM   #15
Engine: DT466/MT643
Re: High RPMs?
As neverenuf said, great trans...same as in my Genesis. It's running at about 1/3 of its rated weight in a skoolie, so it will go just about forever. That's the same trans used in the 50,000+lb trash truck my brother drove.
Jarlaxle
Old 08-28-2011, 12:29 AM   #16
Accordion's Avatar
Year: 1973
Re: High RPMs?
Jarlaxle, that DT 466 has way more torque than my 8 cylinder. I wish I had that motor. Many people claim that it is the BEST motor.
Old 08-28-2011, 06:33 AM   #17
Engine: DT466/MT643
Re: High RPMs?
It is!
But at the power peak, torque kind of doesn't matter. The powerBAND matters (If your power peak is 2800, you will not be climbing hills at 1900RPM; at least, not very well.), but not really the torque peak.
Jarlaxle
Old 10-09-2011, 01:34 PM   #18
Engine: 8.2L Detroit Diesel
Re: High RPMs?
I have an 8.2L Detroit in front of an MT643 Transmission and a 5.29 rear end. It will go 68 on the governor, but it judging by the noise it must be set remarkably high. My bus seems happy at about 58mph on the highway. I would like to be able to drive at about 65 with 20% fewer revs, so so I am installing an auxiliary overdrive. I bought it used, and am about half way through the rebuild. It is a Spicer 7231D. It has a 2.14:1 under drive, and a 1:1 and a 0.86:1 overdrive. I am hoping that this will allow my bus to get better fuel economy on the flats.
Has anyone else installed an overdrive in a bus? Any tips for what might go wrong.
Graham
Intrepid handcycles - Recumbent and handcycle specialists
http://www.intrepidequipment.com
grampsbutler is offline   Reply With Quote
Need help with the high beams Roachhill Conversion General Discussions 9 04-13-2011 09:31 PM
Engine RPMs jkindt Ford Drivetrain 3 09-22-2010 03:40 AM
1973 Gillig Problems--Low RPMS and Will not accelerate furthurNbeyond Conversion Tutorials and How-to's 4 01-22-2010 01:02 PM
HELP! RV to high GoneCamping Conversion General Discussions 0 06-20-2009 09:20 PM
How high should I go? josetann Everything Else | General Skoolie Discussions 3 09-05-2008 03:47 PM
