Old 05-19-2011, 04:52 PM   #1
How to loosen a serpantine belt
Hi, I'm the other half of the Fran project
Seeria has me mostly doing engine work, which is turning out to be interesting. I know just enough about gas engines to get me in trouble ;) and next to nothing about diesels lol.
I'm going to be changing the alternator in a few days. I've done this once before, in something that would have required pulling the radiator to get to the belt tensioner (not an option in a wally world parking lot ). Fun times.
Well this time the tensioner is right there, easy to get to... I'm just not sure how to loosen it, and want to make sure I'm doing it right.
This is the tensioner right? I would assume I just loosen the bolt on the lower one and rotate the arm with the upper pulley out of the way to lower the tension. Is that correct?
Dain is offline   Reply With Quote
Old 05-20-2011, 04:33 AM   #2
Jive Turkey's Avatar
Re: How to loosen a serpantine belt
Yes, that is the tensioner. To loosen just put the square end of a 1/2 ratchet or breaker bar in the square on the pulley side of the tensioner arm and pull.
Jive Turkey is offline   Reply With Quote
Old 05-20-2011, 05:01 AM   #3
lapeer20m's Avatar
correct. NO NEED TO LOOSEN ANY BOLTS ON THE TENSIONER.
Just put a 1/2" ratchet into the square hole on the tensioner and push/pull. It is spring loaded and will move enough to loosen the belt.
Old 05-20-2011, 09:55 AM   #4
Stuff's Avatar
Marked in the picture where the ratchet goes.
Old 05-20-2011, 03:15 PM   #5
Thanks all Saved me a lot of trouble lol
DT466e belt tensioner fail rv8flyboy International | Navistar Drivetrain 2 06-30-2014 08:02 PM
UTAH SKOOLIE seat belt laws Condormfg Skoolie Conversion Projects 13 05-21-2012 09:41 AM
Tensioner Belt Comes Off Radiator Fly Wheel on MCI-9 bus-bro Detroit Diesel Drivetrain 1 08-04-2011 03:18 AM
Belt driven Generators crispyx Conversion General Discussions 5 10-29-2007 09:30 AM
