Old 10-03-2016, 09:20 PM   #11
Chassis: International S3800
Originally Posted by NowhereFast View Post
There's a reason big rigs have air brakes!
the BIGGEST reason is because of the coupling to the trailer...
if all of the brakes were hydraulic it wouldve been a lot harder to couple and uncouple a trailer if all on one system.. imagine having to bleed hydraulics every time you hitched up
one couldve used electrically actuated hydraulic brakes... however brake controller technology didnt exist when big rigs were conceived and air brakes designed...
Old 10-03-2016, 09:29 PM   #12
Chassis: B3800 Short bus
6. Air Brakes - They just plain Sound Bad-Ass!!
Can't argue with that one!
Old 10-03-2016, 09:58 PM   #13
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
1 question, Was the hydraulic brakes vacuum boosted or Hydro boosted?
Tootalltechie is offline   Reply With Quote
Old 10-04-2016, 05:18 AM   #14
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Negative for hydraulic brakes- Most brake fluid is hyrdoscopic, which lowers the boiling point of the fluid. See this white paper in it.
Captain Obvious on deviantArt
Old 10-04-2016, 06:54 AM   #15
they are hydro boost with a backup electric motor that operates the assist in case of engine failure.
Old 10-04-2016, 08:47 AM   #16
That is the same system I am building onto my rig. The master is from a mid sized International truck. Hydro with 4 wheel disks is plenty for my little 8000 pound shorty.
Old 10-04-2016, 11:24 AM   #17
i stand corrected on my hydro brakes in the new bus.. im told all bluebird internationals are 4 wheel disc.. I couldnt tell exactly on my rears but thought it almost looked drum.. but I guess in 2000 it was not dont that way anymore so I probably have disc on that hydro bus.
