Old 09-22-2016, 09:25 PM   #1
Hydraulic or Air Brakes?
Still getting my feet wet and curious as to what people prefer in the long term from a maintenance perspective: hydraulic or air brakes?
J3PO is offline   Reply With Quote
Old 09-22-2016, 09:33 PM   #2
oricha1984's Avatar
Engine: gasser probably
I'm a new noob here, but from what I've read. Air >hydraulic
Sent from my BLU LIFE ONE X using Tapatalk
oricha1984 is offline   Reply With Quote
Old 09-22-2016, 09:37 PM   #3
NowhereFast's Avatar
Chassis: Carpenter
Engine: d466 mechanical
There's a reason big rigs have air brakes!
Nowhere Fast - Sarasota, Florida
NowhereFast is offline   Reply With Quote
Old 09-22-2016, 09:42 PM   #4
Touché - thank you
Old 09-22-2016, 09:45 PM   #5
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
Where I live (BC Canada) need a special addition to my license for air brakes so I went with hydraulic brakes on my bus.
Tootalltechie is offline   Reply With Quote
Old 09-23-2016, 12:50 AM   #6
Don't automatically be fooled by big-rigs use of air brakes. There are plenty of pros and cons about the systems.
Air brakes were first used on trains (in part because trains were designed/constructed first.) Air is used because it's many things - but not not exactly because it's best. The biggest thing about it is that it's free - it's everywhere. If it leaks, no problem - you can get more! You don't need to clean it up if it "spills." It has little weight to it, and it's fairly easy to filter out contaminants (like water.)
Many of the same things can still be said about trucks and trailers - you pick up a trailer that's been sitting around a few weeks, and you just fill the air tank back up again, and away you go. But air is picky - it needs to be dry, if you get water in the system, you can get ice, and things will freeze up.
Air has one BIG advantage - the first brakes were manual - no power assist. That was okay for something like a car. For a truck, you need a bit more force. So you have power-assist brakes - which use engine power to assist your stopping power (vacuum, or hydraulic.) That's great - IF the engine is running. If the engine stops, your power assist goes away - and so do your brakes. The tank of pressurized air sitting under the truck cab doesn't care if the engine is running or not. You've got a fairly long time to get the truck stopped, using the stored compressed air.
What still matters in the end is the ability of the brake system to dissipate the heat generated from friction to stop the vehicle - whatever generates the pressure is secondary.
I mean, we use both pressure systems all the time - air-powered jackhammers and tools, but hydraulic excavators and tractors.
Old 09-23-2016, 07:00 AM   #7
Chassis: International S3800
I'll tell you soon.. I have a bus with air brakes and just bought one with hydraulics so i'll soon know the pros and cons of both!
Old 10-03-2016, 03:22 PM   #8
Any word on your findings?
tad875 is offline   Reply With Quote
Old 10-03-2016, 07:54 PM   #9
Very interested to hear!
Old 10-03-2016, 09:17 PM   #10
I drove both busses one right after the other...
1. AIR Brake - in a hard stop scenerio I can get from seeing the need to stop to braking going to the wheels faster with the air brakes.. maybe 1/2 second to maybe 3/4 second. but thats the difference sometimes in crash vs stop..
2. HYDRAULIC -that good familiar feel of regular car brakes.. more pedal travel... easing into the pedal.. unlike air brakes where you have very little travel... so with hydro you have that car feel.
3. AIR BRAKE - Precise control in slick conditions.. - this one from a situation a few weeks ago where a car pulled in front of me in the rain... it was Very easy to feather the pedal in and out quite quickly to pulse the rear wheels so they didnt stay Locked up... with hydraulic the long slower pedal travel would not allow for pumping.. of course with the air theres the chance you will outpump the compressor and run the pressure low.. but I still had 75 PSI at the end of that stop.. and my bus didnt go sideways in the rain..
4. AIR BRAKE - Failsafe. with an air brake you have an extra braking system that is not present on hydraulic.. that is your rear spring brakes which apply during loss of air pressure... they are REAL brakes.. that also act as a parking brake so 4 wheels in the back t hold it stopped when parked. with hydraulic you often have a single brake on the driveshaft.. which would be tugh to stop a bus in a failure but is fine as a parking brake.
5. Hydraulic brake - ease of repair... typically 2 or 4 wheel disc very similar to car brakes.. so you can likely fix most things on them yourself, or a normal car shop with a big bay can work on them... whereas air brakes take specialized tools and specialized knowledge only big-rig ($$$) shops have..
6. Air Brakes - They just plain Sound Bad-Ass!!
