Old 07-14-2015, 10:25 AM   #1
crazycal's Avatar
I'm having a problem with what I thought was a 100% mechanical bus
When I bought my bus, I thought it was 100% mechanical. On my way back home I ran into a problem with a screeching noise about every 10-15 minutes. I tracked the noise to a device mounted on the left side of the bus next to the drivers seat. It says Panasonic on it. Can someone help find out what this thing is used for?
I'm hungry!
You Gotta Let Me Fly
Old 07-14-2015, 10:38 AM   #2
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
It could be anything from a video recorder to an alarm system to a radio. A pic might help ID it
Captain Obvious on deviantArt
Old 07-14-2015, 10:48 AM   #3
crazycal's Avatar
Don't have a pic right now but will post one later. I did a little more research. It turns out this thing is called an AM/FM radio.
I'm hungry!
Old 07-14-2015, 11:12 AM   #4
Chassis: International 1753
Engine: 6.9 International
Oh man! you got the Deluxe Edition!
Old 07-14-2015, 11:34 AM   #5
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Antenna's probably not connected.
Old 07-14-2015, 12:31 PM   #6
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Its for one way communication... The worst kind...
Old 07-14-2015, 06:19 PM   #7
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
You wanted a mechanical radio?
Old 07-14-2015, 06:27 PM   #8
"old school band"
Old 07-18-2015, 10:10 PM   #9
Note to self: Do Not read new posts with liquid in mouth. Darn near choked to death (and do you know that the nose makes for a great projectile device....too bad it was aimed at laptop)
The-Breeze is offline   Reply With Quote
Old 07-18-2015, 11:38 PM   #10
crazycal's Avatar
You shouldn't shoot liquid out of your nose. It ends up in your keyboard. If you spit it out of your mouth, it hits your monitor and can be easily wiped down.
I'm hungry!
