Old 07-30-2012, 04:04 PM   #1
crazycal's Avatar
King pin replacement
What should this cost. I had my front end steam cleaned then took it to Betts. They showed me my worn king pins. What should this cost to replace? They have a special going for stainless, $850 plus tax. How does this sound?
I'm hungry!
You Gotta Let Me Fly
Old 07-30-2012, 06:35 PM   #2
Re: King pin replacement
No comment on price
I didn't know they used SS for them,I can see the anti-corrosion element,just curious since the lack of carbon is the reason for lack of rust....wonder what parts are SS?
A lot of SS is "soft" and since the bushings need to be reamed to size they can't be harden.
I now must "study" king pin replacement on these only kingpins I have messed with were D60 stuff which was steel and bearings...not solid 1pc pins.
If they are lubricated and clean,is there an advantage worthy of the cost?
Just curious and rambling....this is something I want to do next spring
I will comment that $850 to R&R a truck frontend seems cheap...is this"per side"?
Old 07-30-2012, 07:25 PM   #3
crazycal's Avatar
The price is total and includes an alignment.
I'm hungry!
Old 08-01-2012, 06:31 PM   #4
they should also do the wheel bearings, check brake cams, etc. depending on your type. for example, mine has oil wheel bearings.
i would think this is probably in the ballpark for price, maybe a bit high, depending upon normal shop rates.
it will take someone a few hrs to do all that...
Old 08-01-2012, 06:45 PM   #5
GreyEagle's Avatar
Would it be possible to get a price check at another shop? That will tell you everything you want to know......... I think?
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 08-01-2012, 07:49 PM   #6
Its a lot different after watching some vid's on youtube...a lot easier than I thought.
Old 08-12-2012, 08:31 AM   #7
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
if u got the means,do them yourself,not hard at all....
keith is offline   Reply With Quote
Old 08-12-2012, 08:58 AM   #8
crazycal's Avatar
Front axle weighs over 10k. I don't have the place, tools or the time to do it. I have never seen it done. I know I could figure it out but I don't have the luxury of leaving it apart until I finish.
I did some checking on the price, I was told by several that the price was fair. Some shops are charging as much as $120 per hour for labor and that's not the dealer. I'm going with the $850 quote when I get some extra cash unless I have it done somewhere else if I go a trip and it's lots cheaper.
P.S. that's for the feedback.
I'm hungry!
Old 08-13-2012, 08:24 AM   #9
the guy off IRT has a few vids on youtube that he put up for DIY replacement,fun to watch vids
Carburator replacement 81'gas 109lincoln Conversion General Discussions 5 04-17-2012 01:56 PM
366 replacement or supplier bapos Mechanical and Drivetrains 3 06-19-2011 04:24 AM
Windshield Replacement lornaschinske Conversion General Discussions 5 06-09-2010 10:31 AM
Searching for my replacement bus Gatorskinz Classifieds | Buy, Sell, Swap 0 12-05-2007 12:48 PM
Need some king pin/ wheel alignment help !!!!! abdabbs Conversion General Discussions 5 08-28-2007 08:28 PM
