Old 03-06-2019, 07:57 PM   #41
01mark and others, you might be interested in this report by Timken bearing mfg--see page 19 regarding brinelling. Here is an interesting quote: " Improper mounting and disassembly methods and/or extremely high operational impact
or static loads may cause brinelling."
Seems bearings can flat spot just sitting---- Jack
https://www.timken.com/pdf/5892_Bear...20Brochure.pdf.
ol trunt is online now   Reply With Quote
Old 03-07-2019, 09:31 AM   #42
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
yes I am reasonably sure Chrysler knew what they were talking about when they told us to change out hundreds of bearings because they had flat spots on the rollers. Gene
Gdog 5651 is offline   Reply With Quote
Old 03-07-2019, 09:47 AM   #43
Originally Posted by vintageracer View Post
Funny you say earthquake.
The engineer said maybe if you had repeated earthquakes in the area over a long period of time on that stationary bus.
Well than the engineer is a little bit reasonable.
Races and ball or rollers will flat spot if vibration or enough compression force is applied to pass through the elasticity cycle of the metal.
There is a term people don’t associate with metal. Elasticity
https://www.google.com.au/search?source=hp&ei=9DyBXK7yGcjLjwTf0YIQ&q=elastic ity&oq=elactisi&gs_l=mobile-gws-wiz-hp.1.0.0i10l5.1687.9876..11141...0.0..0.243.783.7j 0j1......0....1.......4..41j0i131j0j46i131j46.BbTp xI6U9mM
Seriousracer is offline   Reply With Quote
