Old 07-30-2013, 09:18 AM   #11
wmkbailey's Avatar
Engine: 3126
Re: MD 3060 transmission 6th gear
Originally Posted by bansil
I think 75 is a little too fast in a bus...have fun stopping in a hurry; it always scares me on interstate seeing big class A's running 70+ 20 feet off the bumper in front of them
Me too. I find that the bus runs good between 55 - 60. Speed limit here is 65, so I keep her at 60. I get there in plenty of time.
I hit the govern at abot 67 mph, but I only get there down hill
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 03-27-2018, 04:01 PM   #12
6th gear
I unlock all my 6th gears via a letter from the OEM of the bus. Allison will send a liability release to sign, then release the calibration to the local Allison dealer.
6th kicks in between 49-52mph depending on the engine, and lowers the engine by 300 RPM which is pretty significant.
To debunct these outrageous hypothesis I've read.. The transmission is designed for 6th gear operations. Your engine computer communicates with the transmission computer. It will downshift when necessary and it will not "bog"the engine.
Cost less than $100 bucks to reprogram and you'll recoop the cost that same week in fuel!
jhagan is offline   Reply With Quote
Old 03-27-2018, 04:33 PM   #13
Chassis: Saf-T-Liner ER
Engine: Cummins ISC 8.3 Allison MD3060
I have the MD3060 and my bus came with 6th gear unlocked. The bus will do 80 without a problem. (We did this at night with no traffic because we were curious)
The bus runs much better at 60-65. I was able to get 10mpg. When my buddy was driving he would go up to 70 and his mileage was about 7mpg to 8mpg.
It's just safer and better gas mileage to stay in the right lane and mossy along at a slower speed.
James
JamieJackson is offline   Reply With Quote
Old 03-27-2018, 04:36 PM   #14
I certainly do not advocate speeding.. We strictly unlock ours for fuel economy purposes. We also activate the "economy mode" which must be activated by Allison.
The 6th range will save fuel. It has saved us hundreds of thousands of dollars.
Jeremy
Old 03-27-2018, 05:16 PM   #15
Have you managed this with a Bluebird?
They seem reluctant to send the release letter that Allison requires.
PNW_Steve is online now   Reply With Quote
8.3 md 3060 mpgquestion Bus dad Mechanical and Drivetrains 24 04-05-2017 06:26 AM
Allison 3060 won't switch from Neutral to Drive wmkbailey Mechanical and Drivetrains 11 11-13-2013 09:21 AM
Low Gear Conversion morriskelly Mechanical and Drivetrains 9 01-01-2011 04:49 PM
Top Gear: Bus Jump Steve Everything Else | General Skoolie Discussions 5 01-14-2007 05:36 PM
My transmission is slipping/popping out of gear! 66ChevyTailgater Conversion General Discussions 5 11-08-2005 08:41 PM
