Old 07-28-2016, 11:32 AM   #1
Minimum cold cranking amps for DT466?
Looking around for batteries. The ones that I'm replacing had 925 cold cranking amps, but I'd take a good priced battery with lower cranking amps as long as it was sufficient. How low can you go with a DT466 and still get the job done? My plan is to maintain the batteries well and only drive the bus a few times a year.
misterW is offline   Reply With Quote
Old 07-28-2016, 04:25 PM   #2
I've driven mine from KY to FL on one group 31 battery. But you really should run two of em. Mine were $75 each at Rural King. A year ++ later and it still starts INSTANTLY.
Roll Your Own Build Thread
