Old 10-14-2004, 12:38 PM   #1
More Questions, more organized
Alrighy, the other day I had some pretty unorganized questions. Let me try again.
Good or bad, if bad why?
Engine
1. Cummins 5.9:
2. DT360:
3. DT466:
4. Ford 6.6:
5. DT408:
Trannys
AT545:
MT643:
Any comments on good drivetrain combos? Gas is not acceptable.
system-f is offline   Reply With Quote
Old 10-14-2004, 06:16 PM   #2
#1 Cummins 5.9 is an ok engine but does not hold up very well in school bus service. Great in a pickup but not very great in a bus. It is the standard cost effective engine in a lot of buses.
#2 DT360/366 Great engine but it lacks some power. It is expensive to rebuilt as most Navistar engines.
#3 DT466 another great engine and you can get it up to 230 HP in a school bus. The DT466 is still a Navistar engine and expensive to rebuild.
#4 Ford 6.6 If I remember correctly this is the Brazillian engine and it is supposed to be a great engine as reliability goes. I have heard from several sources that it is a dog though. In fact I think Jason on this group has this engine in his bus.
#5 DT408 I have not seen this engine is a school bus.
#7 T444E/7.3 I always hear bad stuff about this engine, I would stay away from it. You will find a lot of school buses under 100k miles with a new or rebuilt 7.3 in them.
#8 Cat 3208 The cat 3208 is a sleeveless engine so rebuilding them is not easy. The 3208 is a good engine though and it very common in transit style school buses. This engine is a V8 and is not the best on fuel but it is a good engine.
Transmissions
#1 AT545 this is the Cummins 5.9 of trannys. The AT545 is cheap to buy and just "ok". The AT545 is not a real beefy tranny and does not hold up very well is harsh service.
#2 MT643 This is a much better tranny with overdrive. It will hold up better with heavier loads and will last longer.
For all the technical tranny info check out this site
http://www.industrialautomatic.com/html/onhiway.htm
HTH
busone is offline   Reply With Quote
Old 10-14-2004, 06:43 PM   #3
lapeer20m's Avatar
that was an excellent reply to the original post.
I do have the brazialian made 6.6 liter ford. All indications is that this motor is indestructable, however, it is wimpy and parts are really expensive. My skoolie has over 276,000 on the original engine without a rebuild.
The 5.9 liter cummings: I would not buy a bus with this motor in it,especially the new compuer controlled 5.9. I'd be more than happy to have that engine in a dodge 4x4 pickup however.
The DT360 from what i read is more reliable than the dt466. Both are excellent engines.
The 360 although it is smaller by displacement than the ford 6.6 will run circles around the braziallian motor when it comes to performance. Fuel economy will be much less in a 360 than a ford 6.6. This info comes from the friendly guys at my local bus garage. They currently run both engines in 72 passenger busses. The dt 360 should get close to 7mpg, while the 6.6 gets 8.5. both use the 545 allison.
I would also like to disagree about the cost of rebuilding the dt360. According to my local bus mechanic, an entire rebuild kit can be purchased for under $1,000 bucks. This motor has sleeves and the entire engine can be rebuilt while it's still in the vehicle.
I wouldn't compare the 545 allison to the 5.9 cummings. The 5.9 is a bad skoolie engine! The 545 is very common around here in buses. It's pretty much the only auto trans i've seen in used buses here in michigan. It is pretty reliable, the biggest downside is that It does not have a lock up converter, giving approximately a 10% decrease in power and fuel economy over a manual trans. My bus (1991 Ford 6.6 allison 545) did get a new trans at approx. 150,000 miles. I don't know if this is premature failure for one of these transmissions or if 150k is par for the coarse.
There is a bus on the lot right now with a bad at545 allison, it has about 250,000 miles on the bus. I'll try to investigate and see if that is the original trans.
hope this helps.
In my next bus, ideally i would like a dt466, but i'll settle for a dt 366
Old 10-14-2004, 06:46 PM   #4
lapeer20m's Avatar
one more skoolie diesel worthy of mention is the 9.0 liter internation. According to Greg (who has spent years buying and selling hundreds of used busses) will last pretty much forever. It is huge motor when it comes to displacement, but it makes 180 hp or less making it every bit as whimpy at the ford 6.6 liter.
if you want a motor you won't have to work on, the 9.0 liter is the one for you.
Old 10-14-2004, 10:54 PM   #5
Good point about the 9.0L it is an awsome engine. Not much power but it keeps going and going. It is also excellent on fuel. The AT545 is fine for regular school bus use but I would not want to be hauling and towing cars with it. The MT643 does have a lockup converter and is a much beefier tranny. If I found the right bus at the right price with an AT545 I would probably still get it. I would not however be running it at a full load all the time.
Old 10-14-2004, 11:17 PM   #6
AK-Brando's Avatar
I can't speak from much experience, but my bus has the Ford 7.8L engine. It's basically the same block as the 6.6L with just a longer stroke. At least that's what I can find out about it anyway! The 7.8 is also a Brazillian engine and seems to have plenty of power with the 5-speed manual transmission I have. I can hold 60 no problem, and 65 isn't too much of a stretch either.
About the only down-side I have heard about the Brazillian motors is that parts are pretty expensive and hard to come by.
Good luck!
Brian
'91 Thomas/Ford B700 7.8L Diesel 5-speed (seats removed)
My Bus Pics
My Bus Blog (hasn't been updated in a LONG time)
AK-Brando is offline   Reply With Quote
Old 10-15-2004, 09:08 AM   #7
Les Lampman's Avatar
Hi,
I have a Blue Bird/International (65pax) with the DT466 and MT643 Allison automatic. I drove this bus home from Denver to Seattle, some around our area and just finsihed a round trip from north of Seattle to Redding, CA and back (nice hills!) pulling a 16' boat. I'm very happy with the powertrain and the power available; I'd like a little higher gearing for a bit more speed on the highway and to get the rpm down a bit (right now it runs 57mph at 2600rpm) but it pulls the hills well. So far, in the 4,000 or so miles I've driven the bus, I've maintained just a tad over 9 mpg; worst was about 8.75 pulling the Continental Divide and Lookpout Pass on I-90 coming home from Denver. We got just over 9 mpg overall on the Redding trip with the boat in tow. Right now the engine is set at 180 hp, it can be dialed up to 210 hp at the shop if I want to go that way.
A friend of mine who owns a coach company (and has everything from vans to MCI road coaches) told me to lok for the DT466/MT643 combination...so far I've been very happy with that advice.
I was told to pass on any DT466/AT545 combo I came across; I was told the torque from the DT466 can really beat up an AT545. In an attempt to save money some school districts did specify that combo and I have seen them advertised.
As evidenced by the large number of older and still running gas and diesel skoolies on the road the DT466/MT643 certainly isn't the "only way" to go; I'm sure there are lots of folks happy with other combinations and I just wanted to add my experience with my set up here.
Happy Bussin'
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 10-15-2004, 12:56 PM   #8
Awesome response, thanks.
I am rather confused about the 5.9 cummins. I am getting lots of advice, both on totally opposite ends. I will probably end up getting the 5.9 and at545, but I am searching hard for the 466/MT643 combo. If I get the AT545 I am assuming a swap to the MT643 will not be much of an issue, a near bolt in. I do all my own welding, advanced mechanical work , and fabrication so from what I have been told maintence shouldn't be hard just A LOT BIGGER tools required???(question)
Here is another question I have. Most of these diesel motors have huge displacments with extremely small outputs (tell me torque not horsepower). I have known quite a few people to release power from their diesel by installing a free flowing exhaust, intercooler, higher govener springs. Has anybody tried this? now understand I am talking about releasing power that is already there, not messing with injection pumps or doing things that might cause harm.....and all of this assumes an EGT Gauge has been installed. This is another reason I am looking at the cummins, because high amounts of RELIABLE power are available out of it....assuming it holds up.
Old 10-15-2004, 08:16 PM   #9
The Cummins 5.9 is great in a dodge pickup because load does not weigh as much and in most cases rarly ever moves a really heavy load. In a school bus it takes a beating always starting and stopping and idleing. It also is powering a heavy vehicle that can hold a load of heavy kids. The AT545 will probably hold up ok in regular bus service but I would not want one if I was going to have a heavy conversion like hauling cars. If you can find a bus with a Cummins 8.3 you will be able to get more power out of it easy. Another problem with the AT545 is it is rated for 230 HP 445 lb ft. If you can find one with the MT643 and an 8.3 you will be set. The MT643 is rated for 250HP and 640 lb ft. Of course if you are going to put in a manual you could get higher HP and not worry about burning up your tranny. If you could find a Gillig or Crown bus with a mid ship mounted engine you would still be able to carry a car in the bus and you can find them with IIRC a 12 speed tranny. Those also have a 6v71 or a Cummins 555. Those are ancient engines but you might be able to get some HP out of the Detroit. To take a look at some Gilligs and Crowns check out http://groups.msn.com/TheGilligCoachClub/.
Old 10-15-2004, 09:55 PM   #10
lapeer20m's Avatar
One of the reasons medium and heavy duty diesel engines last so long is the high iron to hp ratio. You're correct, there seems to be very little horsepower compared to the large displacement of any big diesel engine. You can increase the horsepower of an engine, the downside is that you will reduce the lifespan of the engine. higher hp=decreased engine life.
2000, 2001 Lapeer Community Schools purchased several buses with the cummings 5.9 rated well above 200 hp. That's a lot of horsepower from what is probably the smallest commonly availabe diesel for skoolies. Nearly every one of these buses has been towed back to the cummings certified repair facility for new a new injector pump at least once. They are really happy with the performance of these motors, but the engines just keep blowing themselves apart. Now they order all their buses with cat motors, i forget the model.
I would not buy a bus with a 5.9 liter, or the 555 (triple nickle) cummings.
If you really want high performance (i use that term loosly), buy a big gasser, like a fuel injected 454.
Old 10-15-2004, 09:58 PM   #11
there is another engine that is not in your list that you might consider.
The Detroit Diesel 8.2l turbo. reasonable amount of power and fuel economy.
I agree with the rest on the cummins 5.9. Its not a good bus engine. if you look long enough you'll come to the same conculsion. Its a great pickup engine. I'd take one tomorrow.
For the tranny. the MT 643 is better than the MT545. Just check the input ratings. If the mechanical limits are pushed the sooner a mechanical item will wearout. An even better tranny would be the mt653. the 5 speed cousin of the mt643. it'll give you better highway speeds
-dkenny
ps I have a Bluebird bus with a DD8.2l turbo and an MT643 tranny
dkenny is offline   Reply With Quote
Old 10-17-2004, 12:29 PM   #12
-dkenny
Hi there,
I don't believe that that you'd find this to be true; all the information that I'm able to find suggests that the final drive ratios (effective mechanical) on both the MT643 and the MT653 are 1:1. The highway speed/rpm would therefore be indentical for both transmissions in high gear.
Les Lampman
Skoolie.net Gallery
Old 10-17-2004, 02:10 PM   #13
injection pump failures with the newer 24valve dodge motors is an issue even the trucks are having. The newer injection pump doesn't use engine lubrication. (assuming they are using this motor)
a big gasoline motor can never produce the power of a diesel motor. They might make good horsepower but the torque is no comparisson. Besides diesel has more power per once than gasoline.
also I have found some older 8.2s and manual trannys, I assume this is a good combonation
Old 10-17-2004, 05:10 PM   #14
lapeer20m's Avatar
I agree there is more energy in a gallon of diesel fuel than a gallon of gasoline. I dissagree that diesel engines are higher performance than gasoline.
how many diesel sports cars do you find? or diesel race cars?
another added performance benifit of a gas vs diesel is that the gasser usually redlines at a higher rpm giving a higher top end speed for a given gear ratio.
I personally am not an advocate of gas skoolies, but if high performance is what you're looking for, diesel is not the place to look.
Old 10-17-2004, 06:40 PM   #15
I'm a big fan of the 8.2L engines, the wife and I made a 5000 mile trip last year in our Carpenter schoolbus with 8.2l engine and 545 tranny..
EldoMike is offline   Reply With Quote
Old 10-18-2004, 02:04 PM   #16
Guess you haven't seen the guys with Ford Superdutys that drop the Cummins 6B in there and run 11-12 second 1/4 mile times... It's quite entertaining to see an 8000lb truck go down the track that fast. Some of these guys also drive their trucks everyday.
http://www.dhraonline.com/
I live in Texas , Dallas Fort Worth to be exact, and we are one of THE hot spots for truck sales in North America. Dodge sells more 3/4 ton diesels here than anywhere else. I drive 40 miles to work every day and I see Ford Powerstrokes pulling car trailers with 3 full size vans/trucks/cars whatever on them.. Now that is very dangerous (why I am looking at a skoolie and not a Ford/Dodge) but these boys have no problem keeping speed. Of course the gearing isn't there in a skoolie, but the power potential and reliablity is. Not to start an argument, just to understand where I am coming from. Now reality might come and smack me in the face when/if I get my skoolie loaded with my 5k truck on it and a 7000lb trailer behind it.
Now I agree out of the box a diesel is designed to run at 100% all day long..usually at a lower power output than a comparable gasonline motor, but what you can do with a set of tools, a good Exhaust gas temp gauge, and some injenuity to an already turbo charged diesel motor would surprise most.
Old 12-11-2004, 11:55 AM   #17
pangaia's Avatar
What about....
370? What is the stat of that particular engine? It just so happens I'm looking at one now.
Is there a website I can go to for engine info?
pm
'Before you go out seeking revenge you must first dig two holes'--Chinese Proverb
Bright Blessings of the Mother upon you ;)
1990 International Ward Volunteer "Fantastic Voyage"
pangaia is offline   Reply With Quote
Old 11-24-2007, 09:57 PM   #18
beekay's Avatar
Engine: 5.9
Re: More Questions, more organized
I felt the need to bring up this old thread. Any more comments about the 5.9 Cummins in a skoolie? Mine is about 167K right now and I am pricing painting material for my TC2000.
beekay is offline   Reply With Quote
Old 11-25-2007, 09:17 AM   #19
DizzyIzzy's Avatar
Chassis: Chevorlet AT545 Allison auto
Engine: 8.2 litter Detriot Deisel
Send a message via AIM to DizzyIzzy Send a message via MSN to DizzyIzzy Send a message via Yahoo to DizzyIzzy
I have an 8.2l Detroit diesel. I like it it seems to have plenty of power for my needs and it runs great. I don't mind driving slower. I am being safer at slower speeds. I also have an AT545 and it seems to be just fine. Now I don't know much about this motor or trans but they seem to like each other.
"Escapin' through the lily fields
I came across an empty space
It trembled and exploded
Left a bus stop in its place
The bus came by and I got on
That's when it all began
There was cowboy Neal
At the wheel
Of a bus to never-ever land"
DizzyIzzy is offline   Reply With Quote
Old 11-25-2007, 08:43 PM   #20
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
I'm not disagreeing with anything in your post but, speaking as a former military member, it's only fair to let you know that our nation's defense relies on the lowest bidder, not necessarily the best equipment.
Griff is offline   Reply With Quote
