Old 05-23-2018, 01:51 PM   #1
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Mt3060 not going in gear when wet
Anyone ever heard of something like this?
I'm looking at a bus but they say it won't go in gear when it's wet. I have no clue.
Whatthefak is offline   Reply With Quote
Old 05-23-2018, 02:10 PM   #2
Not a symptom that I have heard of before but I can make a pretty good guess that you are getting moisture into a transmission electrical connector or into the TCM itself.
I would think that a failing connector is the most likely.
With luck, somebody smarter than I am will chime in ....
PNW_Steve is online now   Reply With Quote
Old 05-23-2018, 02:30 PM   #3
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
That's kind of what I was thinking, but I don't know much about busses
Old 05-27-2018, 10:45 PM   #4
Year: 2010
Coachwork: IC
Engine: MF DT466
Rated Cap: 81
Not a bus mechanic but I would pull all connectors for a inspection for corrosion and fill with dielectric grease and try again.
Miles O Roads is offline   Reply With Quote
Old 05-28-2018, 06:05 AM   #5
Tryonis's Avatar
Chassis: TC2000 RE
You can also pull codes just by hitting the up and down arrows at the same time. That may tell you more.
Tryonis is offline   Reply With Quote
Old 06-05-2018, 01:44 PM   #6
What's "wet"? Is this after a rainstorm, before a rainstorm, or trying to start after you've driven in the rain?
This is the use case that WD-40 was originally designed and formulated for; drying out electrical connectors. "WD" means "Water Displacing". Reviled as it is, it's still the schniz for curing wetted out distributor caps (as if anyone had one of those anymore). The residue that it leaves behind that everyone hates for attracting dust on surfaces is supposed to inhibit corrosion inside plugged-in connectors.
It's worth a try.
