Old 02-21-2013, 06:05 PM   #1
frank-id's Avatar
Brakes can be upgraded
Brakes can be upgraded to any need. Your bus must have the same brakes as a standard 1 ton with discs in front and drums in the rear. The front discs can be changed to larger discs and the pads upgraded to hi performance. The discs can be modified to grooved and lightened.
The rear drum brakes can be upgraded to disc brakes. Then the discs can be increased to larger discs. The master cylinder would need to be changed because of the fluid volume in the rear disc brakes. With brakes, bigger is better. A Dana 70 rear axle assembly has big brakes
and some gears that will not break. A new set of gears may be needed for better MPG. Frank
Old 02-21-2013, 10:07 PM   #2
the_experience03's Avatar
Re: My bus weight - freaking out
See your other thread. Don't go swapping brake parts haphazardly. There is a lot of calculating that needs to go into it.
Old 02-22-2013, 05:32 AM   #3
I have to ask
What have you put in a shorty bus that is 5000+ lbs? (this is based on a guess of 7000 lb stripped with fuel)
With all the crap in my full size bus I am not even at a 4th of that wt
Have you actually had it weighed?
What was front and back?
Just curious because that is alot of added wt
Old 02-22-2013, 10:56 AM   #4
The gross vehicle weight rating (GVWR), or gross vehicle mass (GVM) is the maximum operating weight/mass of a vehicle as specified by the manufacturer[1] including the vehicle's chassis, body, engine, engine fluids, fuel, accessories, driver, passengers and cargo but excluding that of any trailers.[2] The term is used for motor vehicles and trains.
The weight of a vehicle is influenced by passengers, cargo, even fuel level, so a number of terms are used to express the weight of a vehicle in a designated state. Gross combined weight rating refers to the total mass of a vehicle, including all trailers. GVWR and GCWR both describe a vehicle that is in operation and are used to specify weight limitations and restrictions. Curb weight describes a vehicle which is "parked at the curb" and excludes the weight of any occupants or cargo. Dry weight further excludes the weight of all consumables, such as fuel and oils. Gross trailer weight rating specifies the maximum weight of a trailer and the gross axle weight rating specifies the maximum weight on any particular axle.
Old 02-22-2013, 08:38 PM   #5
crazycal's Avatar
Squeaking brakes only mean that your brakes are squeaking. Grinding is another story and something to worry about. Get that out of the way first so you can stop freaking out. Take it to the mechanic and have them check the brake linings. Make sure the person that did your brake job put the gooey crap on the back of the pads. Don't know if you can do anything about the drums if they are the problem. My mechanic will say I have 50% or 30% left so I have an idea what needs to be done. Unless you drive the bus a lot I can't imagine you have less than 80% left. When you do change brakes, don't get the cheapest pads and shoes. For me, it's not worth the tradeoff. Buy quality.
GVWR and GCVW has been explained. The reason it's at 10k pounds is many states really screw you in the behind after 10K. At least they do in California. That's why you register as a motorhome to avoid the hassle. These numbers are just ratings. If you are a little over, it's no big deal. If you are a bunch over, it IS a big deal. What do you think when you see an idiot driving a mini pickup down the road with 3 tons of broken concrete in the back? I hope he doesn't kill SOMEONE ELSE because of his stupidity. I could care less about the driver as long as he's not behind me.
Hope this helps some.
I'm hungry!
You Gotta Let Me Fly
Old 02-23-2013, 06:34 PM   #6
squealing brakes does not mean that the bus is too heavy. Are they drum brakes? They might need to be adjusted, that could be the problem. When where the brake done last? rust and water can make them squeal also.
100MPG is offline   Reply With Quote
Old 02-23-2013, 10:15 PM   #7
bus-bro's Avatar
Engine: 3208 na boat anchor
Do some panic stops, and see how quick it slows. Generally, with properly bled hydraulic brakes, if the fluid level is OK, but the bakes don't bite, the master cylinder is shot.
Old 03-07-2013, 01:54 PM   #8
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Speaking of brakes what is the cost for a good pair of brake pads for a bus? Mine are only 30% gone and since I only drive it 1,000 miles a year I should have it forever, but I was always curious. I figured $100 a pad.
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 03-08-2013, 01:55 PM   #9
That would depend ENTIRELY on the chassis, brake size, etc. You might be surprised to find out that they aren't TOO terrible. Just deal with someone knowledgeable. I've dealt with these guys many times and they are VERY good. You should be able to find something local that is similar. http://www.brakeandequipment.com/
weight and doors woody Conversion General Discussions 2 11-29-2011 06:26 PM
Actual weight of a Bus Coma Conversion General Discussions 0 08-17-2010 03:16 PM
Bus titles & weight the_experience03 Titles, Insurance, Registration and Money Matters 4 08-27-2009 08:54 PM
weight of WVO nyrockingchairs Veggie Oil | WVO | Biodiesel | SVO 1 06-02-2007 03:55 PM
Bus Weight phillip266 Everything Else | General Skoolie Discussions 3 05-26-2005 09:58 AM
