Old 08-28-2018, 11:36 AM   #1
Engine: t444e
need a wheel bearing
Can someone help me source a wheel bearing and possibly a spindle for my bus? 2001 international/bluebird 3800 with a t444e. Driver side front.
Thanks
ChiliChzPoopTart is offline   Reply With Quote
Old 08-28-2018, 12:45 PM   #2
I would try your local International dealer.
Old 08-28-2018, 12:48 PM   #3
Engine: TE 444
Rated Cap: 12
You are going to have to know which axle you have, there are more than one, you can get that information by taking your VIN to the international dealer and getting the build sheet
Old 08-28-2018, 01:15 PM   #4
Chassis: IH 3800
There should be a part number on the bearing and hub seal. That'll be easy enough to match up. The spindle on the other hand will be an issue. The 3800 chassis is plentiful so I'd check with IH.
Is the spindle damaged/grooved?
For bearings, I'd go with Timken or SKF
Old 08-28-2018, 02:38 PM   #5
Engine: t444e
Thanks guys, I haven't looked at the spindle yet but I am guessing it's fragged because the only thing holding the wheel on is that brake caliper
