Old 09-05-2018, 04:13 PM   #1
shaymcquaid's Avatar
Chassis: 40' MVP-ER
Talking Once again: PLEASE look at this bus! d(^^d)
Thanks for looking
It is an Allison MT643.
What sort of top end and mpg's could I expect?
THANK YOU THANK YOU THANK YOU
2000 Thomas FE MVP 84 Passenger School Bus - B85466-Used2000ThomasMVP
shaymcquaid is offline   Reply With Quote
Old 09-05-2018, 04:26 PM   #2
Likely around 8-10mpg.
If you are willing to spend that much on that bus, call me before you buy. I'll take good care of you
If you shop a bit you should be able to find a similar or better bus for $3k-$5k.
I have seen a few 8.3/3060 equipped buses go for under $3k. Mine was $3800.
Old 09-05-2018, 04:40 PM   #3
brokedown's Avatar
Too much money, not enough bus. Also they don't tell you what transmission it has, so assume it doesn't have one that you'd want.
Old 09-05-2018, 05:07 PM   #4
Chassis: 40' MVP-ER
Its an MT 643
Man. Everytime I think I found a good bus....Its always something
Cons as I see it:
  • Not a Cummings 8.3
  • Sorta high mileage at 180+k
  • Price
Pros as I see it:
  • 40'
  • 78" celing
  • Under bus storage (but not pass thru)
  • Cummings engine
  • Decent tranny
  • Pre-2007 emissions
  • West Coast, not as much rust
Continue to let me know what ya'll think
Old 09-05-2018, 05:24 PM   #5
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
not enough information
will need gear ratio, engine type, wheel size, a picture would also.
Old 09-05-2018, 08:00 PM   #6
Chassis: 40' MVP-ER
Ok. Flame THIS one? Not too familiar with this engine?
https://www.govdeals.com/index.cfm?f...tid=5213#media
Old 09-05-2018, 08:07 PM   #7
They say its a 550, the pic shows a cummins 5.9, and the vin comes back as a Cat 3126.
Old 09-06-2018, 05:31 PM   #8
I have seen several buses offered with a "250hp Cummins CM550".
Google'ing it does not yield much except referencing ISB. My best guess is that it is another name for the 5.9 Cummins.
Or was it Cummings?
Old 09-06-2018, 05:36 PM   #9
2000 had the bad 53 block on the 5.9
Old 09-06-2018, 05:40 PM   #10
Or was it Cummings?
There is a town below me called Cumming. Everyone new calls it Cummings incorrectly. Rumor has it the city below it, Alpharetta, and my town of Dawsonville, above it, are going to be renamed Heavy Breathing and Cigarette, Because everyone knows there is heavy breathing is before Cumming and a Cigarette afterwards.
Old 09-06-2018, 05:51 PM   #11
Are you planning a roof raise? If so, be aware that the sides of that bus angle in a few degrees starting at the bottom of the windows making a roof raise more challenging.
I bought my 2002 Bluebird out of the same area and it had no notable rust. Just a few patches of light surface rust under the plywood.
The MD3060 transmission is the "god standard" for Skoolies. Behind a 250hp 5.9 it should be reasonably powerful.
The mileage is a tad high if the engine has not had major service. Some will tell you that they are "million mile motors". I disagree. So does Cummins. The give the ISB a B50 of 350k miles in normal duty. ( 5.9L 24v Cummins ISB Specs ). That means that by the time they hit 350k miles half of them have needed rebuilding or replacing. School bus duty is considered "severe duty" and has a reduced B50. I cannot find the number but it is lower than 350k.
It looks, to me, to a fairly good looking bus otherwise.
Old 09-06-2018, 05:53 PM   #12
BaaaHaaaHaaaa.
Did I ever tell you about getting thrown out of my bedroom window in the middle of Intercourse?
Old 09-06-2018, 06:05 PM   #13
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Northwest Bus Sales is WAAAAAAAAY overpriced.
Try Midwesttransit.com.
Old 09-06-2018, 06:12 PM   #14
BaaaHaaaHaaaa.
In Pa. ?
Since we're going off track here with strange names. I had a printer who's name was Dick Leaker and a printer named Dick Blick. If I had either of those names I would be in court getting them changed asap.
Old 09-06-2018, 07:45 PM   #15
In Pa. ?
Yep.
The door lock broke and I couldn't get out. I thought that I could reach the drive tires if I climbed out the bedroom window and make a graceful exit. I was wrong......
I dropped from the window to the ground and bruised both of my heels so badly that I hobbled around for a month.
I was on a parking lot in Intercourse PA.
When people asked why I was hobbling around I told them: "My wife threw me out of the window in the middle of Intercourse.".
Old 09-06-2018, 07:55 PM   #16
Yep.
You know how to get your wife really excited while you're having sex? Call her and tell her where you are.
Old 09-06-2018, 08:21 PM   #17
Hmm............
That is a decent looking bus.........
Old 09-09-2018, 11:31 AM   #18
The 5 9 Cummins is a decent motor but they have a poor fuel system the high pressure pump if you take care of it will last three 350,000 but a part of making sure the last that long is that it keeps fuel pressure going to it and you can get new lift pumps for 200 bucks a piece as long as you make sure that those lift pumps are always good the pump should last and in this year range you can swap a p 7100 pump on it it's the high pressure mechanical pump from the 12 valve Cummins and then it's an instant hundred horsepower of that pump and you can run vegetable oil through it if you want and the swap costs less than a new pump from Cummins
01 Freightliner 24 valve Cummins
Brad199 is offline   Reply With Quote
Old 09-09-2018, 05:16 PM   #19
"550" refers to ECM model. CM550 is an old system used across all Cummins platforms of that vintage. It has nothing to do with engine model or HP. I think the latest ECM is CM2850. They are not interchangeable.
bigmackone is offline   Reply With Quote
Old 09-10-2018, 09:52 AM   #20
Chassis: International 1753
Engine: 6.9 International
53 Blocks aren't as much of an issue in a bus due to the engine mounts being a different. Most commercial stuff use a mount on each side of the flywheel housing and a mount below the timing cover. Dodge trucks used a mount on each side of the block and a mount on the tailhousing of the trans.
The 53 blocks had a thin spot in the casting on the side of the block where the dodge engine mount would be located. Through the torque of the engine on the mount, this thin spot would crack and leak coolant. Busses not having the mount there makes it pretty much a non issue.
