Old 05-29-2015, 10:05 PM   #11
Engine: TE 444
Rated Cap: 12
And install a big tranny cooler
Old 05-31-2015, 03:28 PM   #12
Chassis: Vista
Engine: Dt360
Soo I was going to go a head and flush the radiator because as far as I know it hasn't been done in a while and check the airflow like suggested. Ive never cleaned my own radiator before but have done some studying and think I can handle it. I was looking at this
http://www.skoolie.net/forums/f37/19...dure-9652.html
I'm just wondering when I look at my radiator I don't see a cap right on it. There is a container with cap that has a hose that runs to the radiator, is this a surplus container or the only way into my radiator outside of the hose?
There are also several hoses at the bottom next to what looks like a drain plug. Do I remove all these hoses when I pour water into it?
Any knowledge is appreciated greatly, let me know if I'm saying anything funky or have the wrong idea!
Raven19988 is offline   Reply With Quote
Old 05-31-2015, 03:34 PM   #13
Chassis: Vista
Engine: Dt360
Postimage.org / gallery - image, image, image
There are some pictures of exactly what I'm seeing.
Old 05-31-2015, 03:46 PM   #14
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
The radiator cap is on the tank instead of the radiator, the coolant goes in there.
And given the amount of dust in there, I'd probably take a hose to it and wash it off
Captain Obvious on deviantArt
Old 05-31-2015, 03:51 PM   #15
Chassis: Vista
Engine: Dt360
Thanks I thought so. Yeah its pretty dusty a good cleaning is in order for sure! Do I take off all the bottom hoses or just open up the drain valve?
Old 05-31-2015, 04:08 PM   #16
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Easy steps here. Before you open the drain valve, have buckets for the fluid
Old 05-31-2015, 05:39 PM   #17
Chassis: Vista
Engine: Dt360
Maybe unrelated but I noticed this
The piece in the left picture fits and looks like the other ones that are attached to the belt. Not sure exactly what they are or for but I don't want to go ahead and screw it on. Don't know if this would be taken off for a reason.
Any idea?
Old 05-31-2015, 10:37 PM   #18
crazycal's Avatar
Any idea?
There is a sticker with R134 on it. It's probably your A/C compressor.
I'm hungry!
You Gotta Let Me Fly
Old 06-01-2015, 09:01 AM   #19
My bus system holds 25 gallons of coolant....Bring lots of buckets.
dond is offline   Reply With Quote
Old 06-01-2015, 10:26 AM   #20
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Or figure out a way to fill a watertight 30 gallon barrel as it drains...
