05-26-2015, 04:00 PM
Chassis: Vista
Engine: Dt360
Over heating uphill
Helllooooo I've got a couple questions for the pros.
I've got a Thomas safe t liner 38 passenger, engine is strong, no coolant leaks and it does fine idleing and driving flat.
I drive a lot around California and am often going up steep gradual hills. If they are short hills it doesn't have a problem and can get over them nicely without heating up but if it's a long climb it starts to get hot pretty quickly until I have to pull over. First I thought I was pushing it too hard up and tried taking the hills slower, under 20rmp but this still doesn't help.
My bus maxes out at 55 on flat and uphill will go as slow as 30 if it's a big climb.
Wondering if there's a bigger issue a foot or if it should just be expect. I was gonna check the thermostat and see if that's the issue. It's a 93 and everything starting to need replacing soon, but the coolant hoses seem ok. Maybe they are a little clogged or the fan has an issue ?
Any more info would help, it can be scary to over heat and need to pull over on a steep hill with no pull offs.
Thanks yall!
05-26-2015, 04:07 PM
Have you tried dropping it a gear, or from D to 3?
05-26-2015, 04:29 PM
Chassis: Vista
Engine: Dt360
Yeah I've tried taking it up in 3 but never anything else be had the same issue. If I take it really slow it can usually make it but still gets noticeably warmer.
05-26-2015, 04:59 PM
Chassis: All-American R/E
What engine? Front engine?
05-26-2015, 05:04 PM
Hills and inclines can do that. I did Monteagle in Tn with my bus and had to pull over at the top to cool off. Its only a 6% grade but its like 5 miles.
Sometimes going down two gears in needed.
05-27-2015, 06:26 AM
Chassis: I.H.
Turn around and backup the incline. Maybe the bus will think you are going downhill.?
05-27-2015, 09:13 AM
Chassis: International 1753
Engine: 6.9 International
Check inside the radiator for core rot or solder bloom inside the tank. I would also check to make sure the fins aren't all closed shut or plugged up with dirt. I doubt your radiator hoses would cause this or the thermostat (as long as you have the right ones to begin with). If you have an RE, make sure the fan motor, and fan itself are in good shape.
It helps a bunch in diagnosis if you tell us if it's FE or RE, what kind of engine you have, transmission, etc. In these situations it's hard to provide too much information.
05-27-2015, 02:00 PM
The first thing I would check would be to see if the radiator is getting air flow through it.
Our church purchased a bus that had seen service in a school district where more than half of the roads were unpaved. I think I washed over twenty pounds of dirt out of the radiator.
The second part of the air flow equation is to make sure the fan is pulling the air through the radiator and not around the edges of the shroud. Air will take the route of least resistance--if there are gaps around the edges it will pull more air around through the gaps than through the radiator.
The third part of the air flow equation is to make sure the fan is actually working. All of the OEM's have used various ways of engaging a fan. Almost all of them used some sort of drive or clutch that would operate the fan only when needed--a fan will take upwards of 25 HP to turn. You need to make sure the fan is actually working to pull through air through the radiator.
If you are getting air flow through the radiator and the fan is pulling adequate amounts of air through the radiator I would then get an IR thermometer and check the temps on the radiator itself. Your gauge may or may not be telling you the truth about how hot things really are. The IR thermometer will also tell you if radiator is doing any cooling. You should see a minimum of 10% difference between the top and the bottom or side to side of the radiator. If you don't see a difference then you may have a coolant flow issue.
At the same time you are checking the temps of the coolant also check to see the temps on the transmission fluid. We had ten brand new IA built Blue Birds that arrived in WA state without sufficiently sized transmission coolers. Every one of the ten was overheating every warm afternoon as soon as they started up any hill.
If at this point you are still having overheating issues I would then start to be concerned about the water pump or exhaust gases getting directly into the coolant.
But I wouldn't worry about the last two until you have elminiated everything else.
Good luck and let me know if I can help.
05-28-2015, 11:00 AM
Chassis: Vista
Engine: Dt360
Thanks for your responses! It's a Thomson Vista with a international dt360 in it. I don't know too much else besides that it's all stock but am trying to inform myself.
I'm gonna go ahead and clean my radiator and check it out. Thanks for the info!
05-28-2015, 12:01 PM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
As mentioned, check your fan clutch. You probably have an AT545 transmission. Depending on what shape it is in, it will generated A LOT OF HEAT. One of my buses would overheat if I just looked at a hill. If you have a 545, I think you want to keep the rpms over 2000 for the least slippage with your torque converter.
05-29-2015, 10:05 PM
Engine: TE 444
Rated Cap: 12
And install a big tranny cooler
05-31-2015, 03:28 PM
Chassis: Vista
Engine: Dt360
Soo I was going to go a head and flush the radiator because as far as I know it hasn't been done in a while and check the airflow like suggested. Ive never cleaned my own radiator before but have done some studying and think I can handle it. I was looking at this
http://www.skoolie.net/forums/f37/19...dure-9652.html
I'm just wondering when I look at my radiator I don't see a cap right on it. There is a container with cap that has a hose that runs to the radiator, is this a surplus container or the only way into my radiator outside of the hose?
There are also several hoses at the bottom next to what looks like a drain plug. Do I remove all these hoses when I pour water into it?
Any knowledge is appreciated greatly, let me know if I'm saying anything funky or have the wrong idea!
05-31-2015, 03:46 PM
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
The radiator cap is on the tank instead of the radiator, the coolant goes in there.
And given the amount of dust in there, I'd probably take a hose to it and wash it off
05-31-2015, 03:51 PM
Chassis: Vista
Engine: Dt360
Thanks I thought so. Yeah its pretty dusty a good cleaning is in order for sure! Do I take off all the bottom hoses or just open up the drain valve?
05-31-2015, 04:08 PM
Engine: T444E/AT545
Rated Cap: 75
Easy steps here. Before you open the drain valve, have buckets for the fluid
05-31-2015, 05:39 PM
Chassis: Vista
Engine: Dt360
Maybe unrelated but I noticed this
Postimage.org / gallery - image, image
The piece in the left picture fits and looks like the other ones that are attached to the belt. Not sure exactly what they are or for but I don't want to go ahead and screw it on. Don't know if this would be taken off for a reason.
Any idea?
05-31-2015, 10:37 PM
Moderator
Any idea?
There is a sticker with R134 on it. It's probably your A/C compressor.
06-01-2015, 09:01 AM
My bus system holds 25 gallons of coolant....Bring lots of buckets.
06-01-2015, 10:26 AM
Engine: T444E/AT545
Rated Cap: 75
Or figure out a way to fill a watertight 30 gallon barrel as it drains...
