Old 05-26-2016, 02:35 PM   #1
Chassis: E-450
Engine: 7.3 Turbo
Pitfalls of a bus that hasn't been run in years?
Found a bus I'm interested in, but the seller states that it is very hard to start because it sat for 2 years. It will start and run as is, and before it was retired it apparently started easy.
I know that there are pitfalls to buying a bus like this, but I was wondering if any of you have specific information about what these may be. Are there any good threads to read on this issue?
PigPen is offline   Reply With Quote
Old 05-26-2016, 02:52 PM   #2
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Question
Year/make/model?
Close to dead battery/alternator?
Fuel line/pump issues?
All filters clean?
n00b build > https://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 05-26-2016, 05:11 PM   #3
Robin97396's Avatar
Is that sounding like a gasser? Either way you're going to want a tune up and fluids at least. If you'd like to be thorough you'd do you belts and hoses, possibly update the old rubber fuel lines that don't respond well to modern fuels. It would be expensive initially but sounds entirely reasonable and then you know what you've got. Most of the time it's just deferred maintenance that you end up catching up on. I like to do all those things on a new-to-me vehicle anyway, because being stuck somewhere due to a 50 cent hose clamp or a bad hose doesn't make for a good trip. I don't like to wonder about the condition of replaceables, within reason. Still possible to break down, but I'll keep hedging my bets on any used rig. Mountain ready, desert ready. Each one's an adventure in itself.
Old 05-26-2016, 07:37 PM   #4
Chassis: E-450
Engine: 7.3 Turbo
I meant to include a link to the bus. Its an 03 Ford e450 wth the 7.3 turbo.
https://www.govdeals.com/index.cfm?f...42&acctid=5559
My wife and I decided on this style after months of back and forth. They pack a decent amount of size into a small package. The right ones have 6'4"-6'6" and ~15' behind the drivers seat. For what we want to do with it, this will be perfect.
The longer versions with high headroom are hard to find, especially with the 7.3 which is what we want. Outside of auction they seem to require ~3500-5000 but I'm expecting this one to go for less than $1500. I was trying to buy another one from the same school that was in better condition but didn't pay attention to the fact that there was no auto-extend on the bid. I got sniped with 1 second left to go, literally! Went for $1750 which was considerably less than what I was willing to pay
Trying to figure out why this one has been sitting for 2 years at the moment. That to me is the big question.
Old 05-26-2016, 10:17 PM   #5
roach711's Avatar
Rated Cap: 19
$1500 is a decent price for that bus but be aware that you'll almost certainly have to do batteries, tires, brakes, all fluids and filters, and maybe drain the fuel tank if it was parked with a partially full tank.
The Roach Motel
Old 05-26-2016, 10:27 PM   #6
Chassis: E-450
Engine: 7.3 Turbo
Yea, we've been looking high and low for buses like this. We've found 3, and all are asking between 4500 and 5000. Tires are all 50-75%. I think I could negotiate down to 4000 on at least 1.
My thinking was that if I could get this for 1500, that would give me 2500 to play with before I'm at the cost of the other buses. That should account for brand new tires, new batteries, fresh fluids and brakes leaving me ahead of the other options. The concern is something bigger being wrong. Hopefully I can get down there to check it out.
Old 05-26-2016, 10:43 PM   #7
roach711's Avatar
Rated Cap: 19
The engine itself is probably OK; they routinely go 500,000 miles. It's the bolt on's (alternator, AC compressor, steering pump, etc) that go south about as often as those in a car.
A set of tires runs about a grand (just replaced mine), replacing the brakes runs about $750 for parts. Fluids and filters aren't too pricey and the only problem with batteries is that you need two.
Getting a copy of the service records would be a real plus.
The Roach Motel
Old 05-26-2016, 11:03 PM   #8
opus's Avatar
Chassis: All-American R/E
As with any auction bus, buy it with the thoughts you'll have to replace everything. Then if you find out you dont....BONUS!!
Old 05-27-2016, 06:25 AM   #9
Thats the way I do it!
Auction or dealer- the chances are pretty much the SAME.
Old 05-29-2016, 08:11 AM   #10
Chassis: E-450
Engine: 7.3 Turbo
Welp, looks like I bought a bus. I got as many details as I could, and there was nothing that sent up a red flag. I was still skeptical so decided not to even bid 1500. I bid 1257 thinking there was a good chance someone bid 1250, and I was right.
At that price, it's not even much of a risk. We'll see!
Old 05-29-2016, 11:06 AM   #11
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Originally Posted by PigPen View Post
Welp, looks like I bought a bus....
Congratulations!
Dapplecreek is offline   Reply With Quote
Old 05-29-2016, 01:45 PM   #12
Robin97396's Avatar
Nice job Mr Pen. Congrats.
That psychology works well on online auctions. Never go with multiples of five in bidding. I've won many auctions simply using "7" on the end of the bid, occasionally winning by $1. I've also lost by $1 during the learning curve.
Robin
Nobody's Business
Old 05-29-2016, 03:18 PM   #13
Chassis: IH
My usual mechanic tells me these 7.3's have oil-dependent injectors. When the engines run low of oil, the injectors will not fire correctly (or at all). So the first thing I'd check is the oil level and/or do an oil change. This is one reason these engines very rarely suffer low-oil-related breakdowns, they simply stop running before they get that low on oil. Another difficult start possibility involves the glow plugs and/or related circuits that make them work. Since I've never really worked on the 7.3, I don't know enough about it to offer much more advice ...
Old 05-29-2016, 06:06 PM   #14
plus you never know... a bus can run perfectly fine for the auction or dealer.. but they are old and been run hard.. things can just break..
seems most all the busses out there have tires thatare about to go... tread fine, weather cracki g started, etc... im guessing the schools move the tires that are the worst to the busses that are getting sold...
Old 05-29-2016, 07:26 PM   #15
Chassis: E-450
Engine: 7.3 Turbo
Thank you, thank you! It's pretty damn exciting.
So I have to drive this a few hours before I get it back. As described, this shouldn't be a problem. I want to do a quick check of everything before hitting the road to make sure things are as good as possible. Does any one have any suggestions of places that will not make a fuss over working a bit on a vehicle? Would any normal auto parts store be okay with this if we give them some business?
I figure I'll do the following. Please chime in on additional things I'm overlooking:
1. Check all fluids and fluids levels. Any opinion on whether topping of is okay until I can get home and do proper changes/flushes or if I should actually replace all of it before driving in some cases?
2. Inspect tires for excessive wear that may lead to flats. I imagine that like cadillac said, I'll be getting the worst tires they can possible get away with calling fair and not poor. I hope I can get these replaced at home and not before.
3. ???
I know there is more to do. I'm a bit tipsy from a family picnic this afternoon, so the really planning will have to wait til tomorrow
I have ZERO diesel experience, but we do every repair possible on our own cars so I'm not a novice either. I'll be reading dieseliq site and the powerstroke forums obsessively over the next few days to catch myself up to speed as much as possible. Any one have some recommended resources?
Old 05-29-2016, 09:25 PM   #16
,,, I want to do a quick check of everything before hitting the road to make sure things are as good as possible. ...
I would suggest looking up "School Bus CDL Pre-Trip Inspection" on YouTube. Great tutorials on looking things over before one begins a trip.
Old 05-29-2016, 09:54 PM   #17
as for plaxces to work on it? ,mosrt parking lots at auto parts stores (in my area) are barely big enoiygh for the cars they have as customers.. so a big long bus might give them headaches.. however Lowes, home depot, etc usually have huge parking lots and never seem t ocare if people are parking there.. in fact around here thats where the schiool bus drivers all park then run across the street to lunch...
Old 05-29-2016, 10:40 PM   #18
Chassis: IH
Well, you're working with a ~20' mini-bus, not a 40' full size bus. With some care, you should be able to get in and out of most places easily enough. I commonly take a tractor-trailer into my local Auto-Zone (as long as the place isn't completely full).
Items to check at a minimum - Oil level and appearance. Coolant level, including overflow tank. Power steering fluid. Brake fluid (Very Important!). Transmission fluid. Headlights, parking lights, turn signals, brake lights (Helper comes in handy, but can also check reflection off a building if necessary), ideally the upper marker and clearance lights will work, but you may be able to get away with getting home if they aren't. Tire tread and inflation - low tires will build up more heat due to sidewall flexing, and will be more prone to failure. For an E-450, don't be surprised to see inflation of 50-60 or more. Full size buses often run 90-100 PSI. Check the wipers, horn. Test the brakes.
So far, so good? Drop it into drive, ease around the parking lot, get a feel for how it rides. Test the brakes. Again. At some point, the seller (esp. if it's a bus shop/yard) may get a little anxious for you to get going, there's only so much checking and fixing you can do at their location. Did you remember your insurance card? Temp tag? Basic tools, spare fuses (some vehicles have breakers instead - if it's at the bus shop, they might be generous enough to give you a couple if you ask nicely.) I can't think of much more to check.
Old 05-30-2016, 05:53 AM   #19
If you are facing a road trip of more than an hour I would seriously consider getting the oil and filter changed before you head out. If the bus has been sitting any length of time there is no knowing what sort of nasty might be hiding in the bottom of the oil sump.
If it has a serpentine belt I would check it very carefully for any fraying or breakdown of the belt material. If there is any doubt change it out before you head out on the road. Keep the old one handy just in case.
Definitely change out the fuel filter and get a couple of extra ones while you are at it. The odds are pretty good that there is crud in the tank that will clog the filter. You may want to purchase some diesel fuel additive while you are at it. The shelf life of our motor vehicle fuel is more in the realm of weeks rather than years. Most on road diesel has up to 10% bio-diesel blended into the fuel. The chemicals that keep the bio suspended is also hydroscopic. You really do not want to run water through your pump or injectors. Most of the better fuel additives help separate the water out of the fuel.
Good luck and happy trails to you!
Old 06-01-2016, 10:35 AM   #20
Chassis: E-450
Engine: 7.3 Turbo
Wow, tons of great info like always. Thanks everyone!
