Old 01-25-2016, 03:11 PM   #1
Year: 98
Chassis: D
Engine: 7.2L turbo Cat C7 3126
Please help! Replacement temperature gauge
When I bought my bus, the previous owner said that he removed the dashboard temperature gauge because it needed to be replaced. I thought it would be a simple analog display and that it would be easy to find an aftermarket part to replace it.
Even if the new gauge wasn't calibrated perfectly, it would be enough to get me going, I just need to know if there is something horrible about to happen, because it is really scary driving a new bus without this gauge.
I called the CAT supply store, and they said try the manufacturer. I went to the Thomas website, and their affiliates, but I can't find a temperature gauge. I called local autoparts stores, but all their gauges have a thermocouple built in.
I fear that I am not asking for the right thing, like I'm using the wrong terminology or missing something obvious. As I google search, it makes me more confused, because they are talking about water temperature gauges, and oil temperature gauges, and transmission temperature gauges, and engine housing temperature gauges.
Now I'm not sure exactly what I need. I just know there is a empty round hole on the dash with 3 wires with o-ring connectors (red, white, black).
Can someone please chime in and point me in the right direction?
Thanks!
98 Thomas MVP
CAT C7 engine
Allison Transmission
My tiny house blog:
TheBigBusTheory.wordpress.com
gobygoby is offline   Reply With Quote
Old 01-25-2016, 03:28 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Just call the Thomas bus dealer parts dept.
Thomas Bus Gulf Coast GP, Inc.
8806 Mississippi
Houston, TX 77029
Phone:
800-481-6564
Fax: 713-580-8699
Email: busbids@thomasbusgulfcoast.com
Website: Thomas Bus Gulf Coast
Old 01-25-2016, 03:36 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Any Freightshaker dealership can help you with this. They're authorized by Thomas. When you come in, bring the engine code and the VIN with you. It's located on the data sheet above the driver's seat.
Old 01-25-2016, 05:12 PM   #4
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Should be simple stuff to figure out with a little work. It sounds like you have an electric gauge. So that means the white wire goes to the sender. Go on ebay-look for electric water temp gauges. Theres millions. Look on you engine-somewhere in the water system-in the head or on the block probably - will be a small sending unit. (with hopefully a white wire.) Hook up the new gauge to the r-w-b wires. Try it. If the gauge reads odd, change the sender with the one that came with the gauge. But betting you may be ok without changing it.
Old 01-25-2016, 06:32 PM   #5
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
If all else fails go to a local auto parts store. They should be able to help you. They sell aftermarket gauges. They come with instructions. Someone at the store should be able to help you.
Hopeless Busaholic!
Roadrunner is offline   Reply With Quote
Old 01-25-2016, 06:39 PM   #6
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
How big is your hole?
3 wires is power, ground and signal.
VDO is popular in older buses.
http://www.summitracing.com/parts/vd...BBEaAsWA8P8HAQ
wunderhut is offline   Reply With Quote
Old 01-26-2016, 04:49 AM   #7
Year: 98
Chassis: D
I couldn't find any Freightshaker dealerships. Did you mean Freightliner perhaps? At freightlinertrucks.com they linked to Premier Truck Group of Dallas. I will try calling them later today.
Old 01-26-2016, 04:59 AM   #8
Year: 98
Chassis: D
I think you are right about the gauge being analog. So I have a question about the sending unit. I'm guessing it is some sort of thermocouple, is that correct? If so, it should have two wires, unless it's using the chassis as ground. At two of my local auto parts store, the temperature gauges came with 3 wires. There was a black and white pair for the indictor LED, and one metal shielded wire going to the thermocouple. I could not tell if there were a pair of wires inside the shielding, or if there was one wire inside the shielding and the wire mesh was the ground wire, or if the wire inside the metal shielding was the signal wire and the chassis functioned as the ground wire.
Old 01-26-2016, 05:03 AM   #9
Year: 98
Chassis: D
I can measure the hole later today, but 2 1/16in looks exactly right.
Old 01-26-2016, 05:10 AM   #10
Year: 98
Chassis: D
I went to two local auto parts stores, but all the temperature gauges they sold had a brass looking temperature probe firmly attached to them. The indicator wires were black and white and went to an LED. But the employees didn't know how the probe functioned or whether I would be able to cut it off successfully. I will try to find a auto parts store which focuses more on racing, I think they may have a better selection.
Old 01-26-2016, 05:48 AM   #11
Year: 98
Chassis: D
First I want to thank everyone who chimed in, you have all been so helpful!
I especially appreciate pointing me to 'VDO'. I thought I was missing some terminology because my google searches were all bringing up the wrong kind of gauges (ones with probes already attached). The VDO gauges so far look to have detachable sending units and seem to be a better fit both aesthetically and electrically.
For the VDO gauge in the image above, how should I connect the Red-White-Black wires?
Old 01-26-2016, 10:11 AM   #12
Chassis: International 1753
Engine: 6.9 International
We have all blue birds here, so I can't really help you on the gauge part. but the top wires are for the light. the bottom 3 are the actuall sensor inputs. On our busses those wires are all in a 3 terminal plug in so you can't mix them up. If I had to guess. I'd say the black goes on the bottom terminal that's connected to the stud, and the red and white wires will go on the sides. The spade terminals should be labeled on the gauge which goes where like B+, S, and G but I can't see that on your picture.
Your best bet is to contact a Thomas dealer and ask them. Talk to somebody in the parts department and ask them for the correct part number and which wires go where.
The problem with getting a gauge online is that you don't really know what you need. 220, 240, 250, 280 *F? What resistance scale does the sender use? VDO makes 67 different water temp gauges, and that's assuming that it's vdo. Maybe they used isspro gauges. Since you don't have the old one, we just don't know. That's why you should contact Thomas because they should have the answers for you.
Old 01-26-2016, 02:02 PM   #13
Chassis: Blue Bird
Engine: ISC 8.3
Close, but it's more likely a thermistor. A temperature-sensitive resistor. Could have two wires, or could have just a single wire and be grounded to its body so that the block casting/manifold/pipe bung in which the thermistor is mounted is also part of the electrical circuit.
Old 01-27-2016, 03:51 PM   #14
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Yes, I meant Freightliner. Those who drove them call them Freightshakers.
