Old 02-27-2016, 09:53 AM   #11
LPTC's Avatar
Chassis: Thomas
Engine: 5 speed Manual
Rated Cap: 35
Thanks a lot for the detailed post. So to update, woke up this morning and took a volt reading of 12.5. I took off the cables connecting the two batteries and cleaned them up.
I then stripped the pos and neg wires around the ring terminals that connect to the battery and they were both pretty green around where they connected. Also they were hanging pretty loose on the stud posts when I took them off.
I'm heading over to napa to get some new ring terminals and will put them on and then tighten them on to the battery.
I'll let you know if that does the trick.
“If you’re going to be crazy, you have to get paid for it or else you’re going to be locked up.”
-Hunter S. Thompson
LPTC is offline   Reply With Quote
Old 02-27-2016, 10:22 AM   #12
opus's Avatar
Chassis: All-American R/E
Just for clarity purpose, you have an IH with a 5.9 Cummins?
Old 02-27-2016, 10:38 AM   #13
LPTC's Avatar
Chassis: Thomas
Rated Cap: 35
Yes, it's a 1999 freightliner 65 passenger with a 5.9 L cummins
-Hunter S. Thompson
Old 02-27-2016, 10:39 AM   #14
opus's Avatar
I was reading your signature.....
Old 02-27-2016, 12:49 PM   #15
LPTC's Avatar
Chassis: Thomas
Rated Cap: 35
yea this is bus #2 in the fleet
So an update, I cut the terminals and added new ones....BUT I foolishly hooked them up reversed STUPID move!!
realized my stupidity, and hooked them up properly but it had drained the battery, but it actually started chugging, which I haven't heard it do in two days. So that's good I think.
The glow plug icon didn't come on before I went to turn the engine though.
Hope I didn't do any damage to the electrical system with my little slip up.
I'm charging the battery now and will see if I can get her to fire up.
Anyone ever hooked up a battery in reverse?
-Hunter S. Thompson
Old 02-27-2016, 01:23 PM   #16
LPTC's Avatar
Chassis: Thomas
Rated Cap: 35
Update
replaced the terminals, and the blown fuses from my crossed cable adventure, and voila, cranked up without a hitch
-Hunter S. Thompson
Old 02-27-2016, 05:29 PM   #17
Gotta love those Cummins!
alternator, batteries, starter, starting issues, wiring problems
